| 14hp wisconsin on a 1960's craftsman! | |
Thecrazyoldcraftman Member
Age : 27 Join date : 2013-05-27 Points : 4283 Posts : 79 Location : San Antonio
| Subject: 14hp wisconsin on a 1960's craftsman! September 21st 2013, 9:25 pm | |
| ok so Im buying an old 14hp wisconsin TFD and I am simply going to strap it to a 1960's craftsman that a family member doesnt care for any more and am going to a simple pulley swap on a lockered hydro and add brakes. very simple yet deadly build I will post pics of the motor ASAP. | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5761 Posts : 1408 Location : Galway NY
Doc Sprocket Site VIP
cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5021 Posts : 232 Location : fairhope Al.
| Subject: Re: 14hp wisconsin on a 1960's craftsman! September 22nd 2013, 9:36 am | |
| Is it horizontal shaft? those wisconsin's are known for being great engines, i have one on a snapper push mower which the hole thing is about as heavy as a regular riding mower. Which is like the only complaint people have on wisconsin's, they weigh a ton | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! September 22nd 2013, 9:56 am | |
| no pics of the tractor atm. it is still at my grandparents. it is a horizontal shaft craftsman with a hydro transaxle and a starter generator that still works. now I plan on keeping the hydro and locking it. I also plan on pulley swaping it to make a 1:1 and add brakes. more updates should be coming but mainly of the th motor because that is the first thing ill be getting for the project and I plan on doing a major rebuild of the motor sometime later. | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5717 Posts : 1402 Location : Central PA
| Subject: Re: 14hp wisconsin on a 1960's craftsman! September 22nd 2013, 12:52 pm | |
| Is that a twin cylinder I see there?
We have an old 9hp Wisconsin, pretty near all cast iron. Heavy bugger... Its got a big gear reduction unit on it, Id like to build some sort of beefy tractor thing using it. | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! September 22nd 2013, 1:20 pm | |
| - TheBeal wrote:
- Is that a twin cylinder I see there?
We have an old 9hp Wisconsin, pretty near all cast iron. Heavy bugger... Its got a big gear reduction unit on it, Id like to build some sort of beefy tractor thing using it. yes it is | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! September 22nd 2013, 7:11 pm | |
| - TheBeal wrote:
- Thecrazyoldcraftman wrote:
- yes it is
Sweet! This is going to be cool!
How much you paying for it? im paying $200 for it and from what it looks like ill add about $200 more in parts to get her running so I say in total $400 for the motor and the tractor im gettin for free from a family member. | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! September 22nd 2013, 9:06 pm | |
- yes it is
How much you paying for it? im paying $200 for it and from what it looks like ill add about $200 more in parts to get her running so I say in total $400 for the motor and the tractor im gettin for free from a family member. *whistles I wish I could spend that much for an engine... or anything for that matter lol. Are you planning on "restoring" the engine any? Recently there was a tractor show/fleamarket bout an hour away, I think I might have seen an engine like that. Pretty cool. | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! September 22nd 2013, 11:14 pm | |
- yes it is
Are you planning on "restoring" the engine any? Recently there was a tractor show/fleamarket bout an hour away, I think I might have seen an engine like that. Pretty cool. I am planning on doing a major overhaul and getting a set of rings because compression looks pretty low.the only reason I get the money to spend like this is because I budget it out and save a certain percentage of what I make to put towards these things. my total budget will probably be +-$800 or so | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! October 8th 2013, 6:58 am | |
| good News! I finally got back in touch with the Wisconsin seller, he says he finally got a pallet and has shrink wrapped the whole shipment, all i have to do now is mail the money and have it shipped here to its new home in Texas | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! October 8th 2013, 9:20 am | |
| This will indeed be interesting. Several years ago, I had a VERY similar Wisconsin I2 engine. It was big and heavy, but very cool. Highlights included an actual mechanical distributor and fuel pump. Speaking of fuel pumps, I see that yours is missing off the engine. Is the seller including it? If not, you can probably fab a block-off plate and use other means to deliver the fuel.
That old Wisconsin of mine (might have been 16hp, too), I got rid of because of the size and weight. I hadn't made the leap from go karts to tractors and couldn't think of a use for it. D'oh! | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! October 8th 2013, 5:21 pm | |
| - Doc Sprocket wrote:
- This will indeed be interesting. Several years ago, I had a VERY similar Wisconsin I2 engine. It was big and heavy, but very cool. Highlights included an actual mechanical distributor and fuel pump. Speaking of fuel pumps, I see that yours is missing off the engine. Is the seller including it? If not, you can probably fab a block-off plate and use other means to deliver the fuel.
That old Wisconsin of mine (might have been 16hp, too), I got rid of because of the size and weight. I hadn't made the leap from go karts to tractors and couldn't think of a use for it. D'oh! Oh Doc... I think I might have seen an old wisconson at the scrap yard today... was missinf lots of parts, but still had a nifty gas tank... about 2 gallons or so... | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! October 9th 2013, 8:14 am | |
I think I might have seen an old wisconson at the scrap yard today... was missinf lots of parts, but still had a nifty gas tank... about 2 gallons or so... Hey any spare parts you guys can grab to help me would be VERY appreciated even if they don't fit I'll still take it like a fuel tank would be nice to have lol just pm me to get the mailing address | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! October 9th 2013, 8:34 am | |
| I got rid of the engine quite some time ago. Give me some time to look around, I think I still have a bunch of carb parts- but I gotta find them. | |
| Subject: Re: 14hp wisconsin on a 1960's craftsman! October 9th 2013, 11:16 am | |
- I got rid of the engine quite some time ago. Give me some time to look around, I think I still have a bunch of carb parts- but I gotta find them.
take all the time you need I don't plan on this being complete until summer lol | |
