| generator trailer build | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5761 Posts : 1408 Location : Galway NY
| Subject: generator trailer build September 4th 2013, 1:57 am | |
| the power has been going out alot, and my 800 watt HFT genny isnt cutting it. we are looking to get a generac GP7500E, which weighs almost 200 lbs. now, this would not be a problem if i had a garage, aside from my shelterlogic. however, we dont have any place to store a generator, other than my shelterlogic, which is almost 200 yards away from where the generator would need to be. my mom has a bad back, and im not always going to be around to push it up to the plug. however, she can just jump on my tractor, pop a pin in and pull a trailer! here are my "plans" i have written up. -must be towable behind my tractor. -capeable of holding 200+ pounds of generator and fuels. -must be safe to start and run the generator while on the trailer. i am un sure of the dimensions at this time, but i will likely model my dump cart. i might even use parts off it. like the tounge, axle, tires, ect. the cart itsself, structurally is pooch. it has collapsed in on itsself twice now.. to make it safe t run the generator on the trailer, i would ground the gen to the trailer, and the trailer to the ground, using a piece of copper wire and a brass rod driven into the ground. i would like to be able to unhook from the trailer if i need to. just for an example, like hurricane Irene where electric was out for nearly a week. i could unhoom from the trailer and begin cleanup. hauling trees, rakeing, ect. would be nice to do. here is a picture of what i have drawn up. let me know what you think. | |
| | | Guest Guest
| Subject: Re: generator trailer build September 10th 2013, 11:25 pm | |
| excellent idea all around. only thing - to make it stable, have scissor jacks or something at all 4 corners to keep it from going rolling when in use. |
| Subject: Re: generator trailer build September 10th 2013, 11:27 pm | |
| i would probably get a set of tire chocks. but scissor jacks are not a bad ideer. could help level it too. generally a good thing | |
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
| Subject: Re: generator trailer build September 11th 2013, 10:07 am | |
| If it's particularly heavy, you could make it so the ground rod is hooked to and driven into the ground by the scissor jack. | |
Age : 49 Join date : 2012-04-05 Points : 5701 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: generator trailer build October 14th 2013, 11:49 am | |
| - TheRainbowBoxer wrote:
- If it's particularly heavy, you could make it so the ground rod is hooked to and driven into the ground by the scissor jack.
i do indeed like that idea... im making notes of all these things.. well, since i just bought a truck, funds are a bit short | |
| Who is online? | In total there are 48 users online :: 0 Registered, 0 Hidden and 48 Guests
