| lights don't work ! | |
murrey and me New Member
Age : 24 Join date : 2013-06-02 Points : 4209 Posts : 7
| Subject: lights don't work ! July 26th 2013, 9:11 pm | |
| hi i have a 1995 Murray and the lights don't work i don't know if it the the switch in the key or the wire.
thanks | |
| | | Speedfreek241 Member
Age : 26 Join date : 2013-07-12 Points : 4329 Posts : 137 Location : Loxahatchee
| Subject: Re: lights don't work ! July 26th 2013, 10:48 pm | |
| is the motor on, sometimes when the engine is not running the lights don't come on. | |
| | | k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5371 Posts : 1135 Location : Southern Florida
| Subject: Re: lights don't work ! July 26th 2013, 10:59 pm | |
| Could be a number of problems, wires connected?, loose connection, ripped wire, bad key, and have you unplugged and plugged the light plug, and are the bulbs blown? | |
| | | Doc Sprocket Site VIP
| Subject: Re: lights don't work ! July 27th 2013, 7:47 am | |
| Step one- Check the fuse!
Beyond that, check the bulbs. Then you're into checking the wiring, grounds, terminations, switches, etc.
To make sure the bulbs are good- take the wires off them. Get two lengths of new wire, and run one lead from each terminal on the bulbs to each terminal on the battery. Polarity doesn't matter. If the bulb lights, it's good- reconnect it.
To check the light switch- disconnect the wires to the switch, and connect the two wires together, start engine. If lights come on, switch is bad. | |
| Who is online? | In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests
