| Briggs carb butterfly valves dont work right? | |
+3Doug xxXMowerdudeXxx truckin42 7 posters |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5503 Posts : 1070
| Subject: Briggs carb butterfly valves dont work right? April 16th 2013, 3:48 pm | |
| I need help my briggs and stratton 20hp v-twin is acting like the choke is the throttal and the throttal does not doing anything now. And i dont have them mixed up. This motor ran fine friday. | |
xxXMowerdudeXxx Established Member
Doug Site Owner
| Subject: Re: Briggs carb butterfly valves dont work right? April 16th 2013, 4:08 pm | |
| The choke is the one furthest to the outside, the throttle is the one on the inside.
Your question is pretty vague. Need more information. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Briggs carb butterfly valves dont work right? April 16th 2013, 6:18 pm | |
| Well guys i didt think i would have to clean the carb since i cleaned it like somtime last year but i was talkin to J* and he said to clean it so i will clean the carb and see what happens. | |
offroadredneck Member
Age : 26 Join date : 2013-01-03 Points : 4418 Posts : 64 Location : plantcity FL
| Subject: Re: Briggs carb butterfly valves dont work right? April 17th 2013, 10:01 am | |
| - offroadredneck wrote:
- You did one of two things, either you put your carburetor on backwards or you have the throttle connected to choke.
I sont think its possable to put it on backwards, lol, did u clean it yet? | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5701 Posts : 959 Location : Mansfield, Ohio
Thunderdivine Veteran Member
| Subject: Re: Briggs carb butterfly valves dont work right? April 18th 2013, 11:02 am | |
| - truckin42 wrote:
- Thunderdivine wrote:
- #1 No lock tite, the disc fell off?
#2 More fuel #3 No Idea, since I really don't know your setup. What do u mean disc fell off? Umm unsure what its called. The butterfly? | |
| Subject: Re: Briggs carb butterfly valves dont work right? April 18th 2013, 4:53 pm | |
#2 More fuel #3 No Idea, since I really don't know your setup. What do u mean disc fell off? Umm unsure what its called. The butterfly? Oh ok. | |
greener179 Member
| Subject: Re: Briggs carb butterfly valves dont work right? April 19th 2013, 6:32 pm | |
| - Stretch44875 wrote:
- just looked at your video. Looks like your gas pedal cable is holding the throttle open. That is why when you take the choke off, the engine revs up.
I thought of that when i was building the gas pedel but when i started it and it was ideling. | |
| Subject: Re: Briggs carb butterfly valves dont work right? April 19th 2013, 9:20 pm | |
| Well tbh I never knew you took it off.
Just a tip for next time, Always write what you have done with it from stock settings. (Tho you posted a video of it eventually). Also try to remember if you just changed something recently.
Cool it works again. | |
| Subject: Re: Briggs carb butterfly valves dont work right? April 19th 2013, 9:23 pm | |
- Well tbh I never knew you took it off.
Cool it works again. Yeah. Im gonna buy a project build book. | |
