 need help with valves on a 21hp briggs v-twin
xxXMowerdudeXxx
need help with valves on a 21hp briggs v-twin  Empty
PostSubject: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 10th 2013, 5:42 pm
we got the one cylinder just perfect, but the other one is a pain, its backfiring through the carb. we unplugged the spark plugs to make sure it is the one we think it is and its the right one if you are in front of it, we had the intake clearances all the way up to .009 from .004, it got better, but should we just keep going till it quits or do the exsust need to be messed with too, please help. we're stumped
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 10th 2013, 6:05 pm
Wo air filter they can anyway u tune it.
Chopperhed
Chopperhed
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 10th 2013, 6:30 pm
It could be poor tuning, a bad plug or excess carbon build up on the piston and head.
Set both valves to stock, and look for other problems.
xxXMowerdudeXxx
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 10th 2013, 6:32 pm
it hasent ran in two years, and from what im seeing online its the carb
Chopperhed
Chopperhed
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 10th 2013, 6:35 pm
Most likely the problem.
xxXMowerdudeXxx
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 10th 2013, 6:38 pm
and most had to buy a new one, which is 100 bucks
Chopperhed
Chopperhed
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 10th 2013, 6:58 pm
A good cleaning, and it should be fine. These carbs are very simple.
xxXMowerdudeXxx
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 11th 2013, 8:07 pm
i figured it out, its got to do with the diodes-kill wires, i pulled them off and it started to work fine
do you know where i could get some new ones, it looks like you just buy a new harnes, it also goes to the carb shutoff, then theres a plug at the other end
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 11th 2013, 8:10 pm
Whats wrong with your wires exactly?
By diode im assuming you mean the carb fuel solenoid. For mine instead of messing with it I just put one end to ground (already was on ground) and the other to a positive source.
xxXMowerdudeXxx
PostSubject: Re: need help with valves on a 21hp briggs v-twin    need help with valves on a 21hp briggs v-twin  Icon_minitimeMarch 11th 2013, 8:59 pm
the wires that come off the coil go to a diode and merge to go to the other things, the diodes are bad and they were cross talking each the causing it to backfire, i un plugged the two wires and it works perfectally fine now
» Briggs carb butterfly valves dont work right?
» 11 hp Briggs or 14 hp twin cylinder opposing
» Briggs twin
» Briggs and Stratton Opposed Twin Q/A 's!
» Briggs opposed twin problems
