| 11 hp Briggs or 14 hp twin cylinder opposing | |
1MurrayMayhem1 New Member
Age : 55 Join date : 2011-10-29 Points : 4779 Posts : 5 Location : Tuscaloosa,Alabama
| Subject: 11 hp Briggs or 14 hp twin cylinder opposing January 14th 2012, 7:59 pm | |
| whats your thoughts an 11 hp flat head Briggs or a 14 hp twin opposed Briggs, both are older engines and will be governed/ will be goin on a locked 4 speed Murray 92 ish model / tires 20 plus rear and front. Probably keep factory pulley on front and a 4 inch in the rear. Making for mud and trails. whats your thoughts/ more specifics on my youtube 1darron1 Little Murray Thanks for your thoughts and opinions. | |
| | | Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5355 Posts : 170 Location : Ontario Canada
| Subject: Re: 11 hp Briggs or 14 hp twin cylinder opposing January 14th 2012, 8:11 pm | |
| the 11 should be enough power for what you need but the way i look at it is the bigger the better i used to have a tractor with 25x12.5 mud tires on it and it would do 30mph i never had a problem with lack of power and it has a briggs 11hp | |
| Subject: Re: 11 hp Briggs or 14 hp twin cylinder opposing January 14th 2012, 8:43 pm | |
| Is the 11hp a cast iron cylinder? I have an 11hp that I'm starting to mess with and it's an aluminum cylinder. So the twin might be a better choice just from a durability standpoint. The twins aren't easy on gas though. | |
| | | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4936 Posts : 208 Location : Tennessee
| Subject: Re: 11 hp Briggs or 14 hp twin cylinder opposing January 15th 2012, 7:35 pm | |
| For power - go with the twin - plus is you wont need to rev the heck out of it if you get stuck either - i ran a 18HP twin on my mod murray - had tons of power for speed. As much as i had it running around, it didnt seem to use a whole lot of gas.
I ran a 10HP briggs on my agway when it was stock ( came with it) - it did okay for power ( when it ran right), just lacked traction ( turf tires) - im planning on using a 11HP briggs on it in its mod form , should be plenty for what riding ill do with it.
Another mod youll want is a gas pedal/hand throttle - itll give tons better throttle response then the stock throttle setup.
Stock tires will be okay for lite stuff, for more traction go with a AG tire or ATV tire . | |
| Who is online? | In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests
