 briggs and stratton 15hp twin cylinder governor Help?
brownjon4
brownjon4
briggs and stratton 15hp twin cylinder governor Help? Empty
PostSubject: briggs and stratton 15hp twin cylinder governor Help?   briggs and stratton 15hp twin cylinder governor Help? Icon_minitimeAugust 9th 2012, 11:41 am
i have a briggs and stratton 15hp twin cylinder were is the governor at. i am use to the plastic flaps for a governor any help would be nice
AcreFarm
AcreFarm
PostSubject: Re: briggs and stratton 15hp twin cylinder governor Help?   briggs and stratton 15hp twin cylinder governor Help? Icon_minitimeAugust 10th 2012, 7:37 pm
Your twin uses a mechanical governor located inside the block.
PostSubject: Re: briggs and stratton 15hp twin cylinder governor Help?   briggs and stratton 15hp twin cylinder governor Help? Icon_minitimeAugust 10th 2012, 9:19 pm
Yeah - on opposed twins the governer link is located under the carb . Unless the motor is prepped to run w/o one , i wouldnt remove it. Beside over revving the motor, the flywheel/motor can explode.
Twins have more then enough power even using the governer - i propelled my 18HP opposed twin murray up to 40mph using the governer ( I probably wouldve gone faster if it handled better - was a serious handful to drive at high speeds) - trick was to use a hand or foot pedal that snapped back as soon as the gas was let off - gave crisper throttle response, more power.
Another way for more power is to adapt a motorcycle carb or snowmobile carb along with a KN high flow air filter.
My murray was a shift on the go type trans , meaning no clutching while upshifting, and faster shifts - i ran a 6" motor pulley and 4" trans pulley along with 4 8" rims , tapered bering front hubs - slightly larger wheels will give some more speed, but itll get some lag when taking off.
I mentioned the steering was horrible for a basically stock tractor , along with pretty much non functional brakes - a combo not good for 30plus MPH..... its reincarnation will be built for those speeds .
A future build is a super mod, using an 18HP twin, either a RAGB ( right angle gear box) or 700 peerless , straight axle , lowered to the hilt .
brownjon4
brownjon4
PostSubject: hello    briggs and stratton 15hp twin cylinder governor Help? Icon_minitimeAugust 11th 2012, 4:15 pm
how do you hook up a gas pedal i seen it done on you tube with a bike brake what all do you need to do to get that to work right .
PostSubject: Re: briggs and stratton 15hp twin cylinder governor Help?   briggs and stratton 15hp twin cylinder governor Help? Icon_minitimeAugust 13th 2012, 6:19 pm
Heres one set up on my twin 18HP briggs -
briggs and stratton 15hp twin cylinder governor Help? Thrott11
Heres one on my mod MTD with a single 14.5HP OHV briggs :
briggs and stratton 15hp twin cylinder governor Help? File0018
Heres how i set up my foot pedal on the MTD:
briggs and stratton 15hp twin cylinder governor Help? File0019
I used plain bike shifter/brake cables and cable clamps - each end of the cable needs a spring to snap back correctly.
» 11 hp Briggs or 14 hp twin cylinder opposing
» Briggs Opposed Twin Governor Problem
» 18hp briggs twin cylinder opposed power problems. PLEASE HELP!!!
» briggs and stratton v-twin spark plug (confused)
» Briggs and Stratton Opposed Twin Q/A 's!
