 12 hp puking oil our ccv
Fattypipemuarry
Fattypipemuarry
12 hp  puking oil our ccv Empty
PostSubject: 12 hp puking oil our ccv   12 hp  puking oil our ccv Icon_minitimeJuly 17th 2013, 9:40 am
The motor ran perfect then I busted the rear end an it set for a week. I started it today and the crank case vent is puking oil into my carb, I tool the vent tube off and it stopped. Any suggestions?
PostSubject: Re: 12 hp puking oil our ccv   12 hp  puking oil our ccv Icon_minitimeJuly 17th 2013, 10:07 am
Did you check the oil to see if it has water in it or to much oil because when I had water in my mower it had a ton of blow by and this will also happen if it is overfilled with oil
http://www.lastdropgarage.com
PostSubject: Re: 12 hp puking oil our ccv   12 hp  puking oil our ccv Icon_minitimeJuly 17th 2013, 6:08 pm
Yup! Check your oil level. If it's on the high side, suspect water ingress, and drain that sucker into a clean catch can. If the oil appears okay, put it back in to the correct level (or use this opportunity to change it). The other thing to look for besides water, is fuel. If it appears diluted or has a strong odour of gasoline, get rid of it.
PostSubject: Re: 12 hp puking oil our ccv   12 hp  puking oil our ccv Icon_minitimeJuly 17th 2013, 7:04 pm
My friend had over half a quart of gas in his oil and it started coming outta the tube. A quick change and it was fixed.
» 12.5 PH B&S Puking gas
