 70's Wheel horse C-120 mud crawler trail rider
tscustoms
RuggBateman
donaldcon
offroadking
MoMower
TroyBilt Pony
T-Dub13
murrayracer
gearheadmike
mudmonkey06
Jerbear0612
greener179
32 posters
Go to page : Previous  1, 2, 3, 4, 5
Hillbilly Offroading
2019 Build-Off Entrant
1st Place Build-Off 2020
70's Wheel horse C-120 mud crawler trail rider - Page 5 Empty
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeFebruary 20th 2020, 9:37 pm
Nice welds. Mig?
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeFebruary 21st 2020, 10:29 pm
Thanks, they are tig
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeFebruary 24th 2020, 2:03 pm
70's Wheel horse C-120 mud crawler trail rider - Page 5 77346810
70's Wheel horse C-120 mud crawler trail rider - Page 5 A56fc110
70's Wheel horse C-120 mud crawler trail rider - Page 5 Dade0e10
Got some more work done on the new clutch rod, got the rod drilled and tapped for grease, you can see the two grease ports I drilled, let me tell you drilling 7.5 inches deep was no fun. Then I realized the rod was about a 1/8 to short so I recessed the end of the arm.
BlakeGroce
BlakeGroce
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeFebruary 27th 2020, 5:25 pm
Looks good! Way better than the factory. I had to drill out the clutch pivot holes and install bushings on mine too but luckily enough nothing else was wore out. 70's Wheel horse C-120 mud crawler trail rider - Page 5 2731072446
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 7th 2020, 8:05 am
70's Wheel horse C-120 mud crawler trail rider - Page 5 11cfc110
70's Wheel horse C-120 mud crawler trail rider - Page 5 B2bae510
70's Wheel horse C-120 mud crawler trail rider - Page 5 31ed9510
built a "6 pack rack" for rusty so I had a place to carry cold beverages at haspin, it turned out great and was super awesome. Went to a little different pulley setup, 7.25 front and 6 rear and the new cast iron pulleys seem to work significantly better than the sheet metal pulleys they replaced. they actually gripped the belt so good that they made the clutch not work well until I built all the guards and keepers you see in the pics. basically the belt goes out and hits all the guards with the clutch in and the guards hold the belt off the pulleys and now the clutch has never worked better. which is nice because it hasnt worked great since I went from my original setup of 6 inch motor and stock rear. But I feel like its really ready for TTC now since it worked great all week at Haspin
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 7th 2020, 8:07 am
70's Wheel horse C-120 mud crawler trail rider - Page 5 982a3510
70's Wheel horse C-120 mud crawler trail rider - Page 5 72456310
70's Wheel horse C-120 mud crawler trail rider - Page 5 2dd54710
Built a new intake and mud guard for Haspin also as I was tired of having to clean a mud covered filter every ride since the belt slings mud and water everywhere, Even has kind a "cold air" intake now sucking clean cool air from the head light hole. added a led light bar too and man that thing is awesome for night rides.
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 7th 2020, 8:09 am
70's Wheel horse C-120 mud crawler trail rider - Page 5 6a7a0410
70's Wheel horse C-120 mud crawler trail rider - Page 5 Aa0b0d10
just a couple pics of one of the new trails Im working on, its a cool technical hill, your tires chew the whole way up but I can just idle up it in low gear and the turns really make your butt pucker
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 7th 2020, 8:33 am
Those look like a ton of fun man! Wonder if the mk2 could make it up 70's Wheel horse C-120 mud crawler trail rider - Page 5 1098998679
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 7th 2020, 9:57 am
I’d say it could, but you would be stuck in the mud pretty quickly at my house I’d guess, I cut my trails like obstacle courses more than trails really, lots of logs and mud and big hills.
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 7th 2020, 10:16 am
Yeah mud is definitely not my strong suit. Figured that out at haspin’18 lol...spent more time getting unstuck than actually riding
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 24th 2020, 8:19 pm
70's Wheel horse C-120 mud crawler trail rider - Page 5 Dd9d8010
70's Wheel horse C-120 mud crawler trail rider - Page 5 4796ee10
70's Wheel horse C-120 mud crawler trail rider - Page 5 832e7410
Working on a super heavy duty steering setup, will be ball bearing lower shaft and bushings on the column
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 24th 2020, 8:23 pm
70's Wheel horse C-120 mud crawler trail rider - Page 5 E32cc010
70's Wheel horse C-120 mud crawler trail rider - Page 5 Fa746710
Toon my spare gx390 head and did a mild port job on it, got a slightly stiffer set of valve springs to
BlakeGroce
BlakeGroce
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 25th 2020, 3:44 pm
Looks good bub!
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 26th 2020, 10:23 pm
70's Wheel horse C-120 mud crawler trail rider - Page 5 51ba9610
70's Wheel horse C-120 mud crawler trail rider - Page 5 C39dc010
70's Wheel horse C-120 mud crawler trail rider - Page 5 Eef1ba10
Got the block done now to finish the support for the other end and the steering column
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeJuly 27th 2020, 12:09 am
Very nice.  Looks way better than the original!
70's Wheel horse C-120 mud crawler trail rider - Page 5 Sig115PROJECTS:
70's Wheel horse C-120 mud crawler trail rider - Page 5 Sig21470's Wheel horse C-120 mud crawler trail rider - Page 5 Sig314
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeSeptember 24th 2021, 4:51 am
70's Wheel horse C-120 mud crawler trail rider - Page 5 Cfe86610
70's Wheel horse C-120 mud crawler trail rider - Page 5 59b6f510
70's Wheel horse C-120 mud crawler trail rider - Page 5 Bb09a310
Random photo dump, rustys still out there kicking ass and taking names, one pic of my custom intake I built so I could run a dirt bike carb. If anyone’s interested I’ll post up more pictures later
PostSubject: Re: 70's Wheel horse C-120 mud crawler trail rider   70's Wheel horse C-120 mud crawler trail rider - Page 5 Icon_minitimeSeptember 24th 2021, 4:55 am
70's Wheel horse C-120 mud crawler trail rider - Page 5 5c72ef10
70's Wheel horse C-120 mud crawler trail rider - Page 5 3bd3ad10
Couple more recent pics from TTC and waterproof testing
Page 5 of 5Go to page : Previous  1, 2, 3, 4, 5
» [Finalist] [22 BO] MN MUDDER Wheel Horse Pulling tractor "HORSE N AROUND"
» Destructive's 1973 Wheel Horse 12 (Wheelin Horse)
» Wheel horse work horse mud rig
» 94 mtd mudder/trail rider
» 04 husqvarna mudder/trail rider
