| New snorkel and custom hood design for my mower | |
+4redlinemotorsportts crazykid1994 richie thomas k2500life 8 posters |
Chopperhed Moderator
| Subject: Re: New snorkel and custom hood design for my mower July 2nd 2013, 10:34 pm | |
| That's similar to mine, and yes it id subject to getting wet, and bogging,
A simple shield would help that. Use a bigger can and cut the top off, trim the sides to the height of the filter. drill some drain holes in the bottom. adapt the bottom to whatever you are using for a filter base.
For my use, since I don't get a whole lot of mud access. I don't really worry about it.
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5371 Posts : 1135 Location : Southern Florida
Craftsman Dude Member
Age : 29 Join date : 2012-09-08 Points : 4612 Posts : 145 Location : MS
Age : 30 Join date : 2013-03-18 Points : 4925 Posts : 618 Location : loxahatchee, florida
| Subject: Re: New snorkel and custom hood design for my mower July 5th 2013, 8:25 am | |
| a little bit of seepage general you will burn off. i know i have had water splash over my engine and flooded the carb and it still kept running because it wasnt to much to kill my engine. | |
| Subject: Re: New snorkel and custom hood design for my mower July 5th 2013, 8:57 pm | |
| Well I found out today when I went to ride my mower that was sunk completely under water, that it got water in the oil and had a ton of blow by so now I have to drain it out change it and hope I didn't damage anything when I ran it today | |
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: New snorkel and custom hood design for my mower July 8th 2013, 10:36 pm | |
| it wont help the blow by obviously. just maybe help the oil splash inside. its really easy as long as you drain the oil first and soak the bolts with wd40 or penetrating oil spray | |
