| LMM's OFF-ROAD MOWER | |
+18mudmonkey06 willis923 Jerbear0612 Doc Sprocket TheBeal motorizedeverything matt-man Stretch44875 Cr8zyB0b k2500life crazykid1994 craftsmancole redlinemotorsportts Craftsman Dude TheRainbowBoxer MowBandit richie thomas LAWN MOWER MUDDER 22 posters |
| Subject: Re: LMM's OFF-ROAD MOWER September 20th 2013, 10:12 pm | |
- I see you took FF"s advice, nice tires!
Yep Fearless inspired the project of the craftsman mudder, then in a shout out vid he mentioned this so I came here and got the idea for the craftsman RALLY! So yeah I got inspired!! | |
| Subject: Re: LMM's OFF-ROAD MOWER September 21st 2013, 5:48 pm | |
| Tomorrow the rally will be going to my friends place to romp (they all have four-wheelers ) so I will hurry up and get my brakes connected and get it ready for this AWESOME romp. He has a mudding hole!, can't wait to try it out! | |
mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4594 Posts : 327 Location : Rindge, NH
| Subject: Re: LMM's OFF-ROAD MOWER October 12th 2013, 6:18 am | |
| i think its funny that w painted our tractors the same way almost except you did a better job than i did | |
| Subject: Re: LMM's OFF-ROAD MOWER October 12th 2013, 3:15 pm | |
| - mudmonkey06 wrote:
- i think its funny that we painted our tractors the same way almost
except you did a better job than i did Yeah I realized that, lol. | |
Doc Sprocket Site VIP
| Subject: Re: LMM's OFF-ROAD MOWER October 24th 2013, 7:37 pm | |
| - Doc Sprocket wrote:
- Hell, we're still waiting for the previous batch of pics!
Which one is that *looking through pictures*. | |
| Subject: Re: LMM's OFF-ROAD MOWER November 24th 2013, 9:14 pm | |
| I never thought I would do this...
I swapped out my single cylinder 13.5hp Briggs for a 20hp V-TWIN Briggs!!! I got it all installed, except it need a carb re-build and possibly a new fuel pump. | |
| Subject: Re: LMM's OFF-ROAD MOWER November 24th 2013, 9:21 pm | |
| Mr. you BETTER have duals or some kinda custom exhaust. Its almost a sin if you dont. LOL | |
GenevaCustoms Member
Age : 27 Join date : 2013-09-24 Points : 4415 Posts : 315 Location : Florida
| Subject: Re: LMM's OFF-ROAD MOWER November 25th 2013, 6:35 am | |
| The tires and wheels painted just makes it look so much badass and complete lol | |
| Subject: Re: LMM's OFF-ROAD MOWER November 25th 2013, 3:55 pm | |
- Mr. you BETTER have duals or some kinda custom exhaust. Its almost a sin if you dont. LOL
LOL Don't worry Red it already has like 6-8" headers. Also had it running for the first time in like 10 years (the carb/ fuel-pump is blocked so it was only running on carb cleaner). | |
| Subject: Re: LMM's OFF-ROAD MOWER November 26th 2013, 2:09 pm | |
| Well I am happy today because I had it going in the snow. Well anyway it runs good and strong and I can't put the hood on because the pipes would melt the plastic on the front. I might be flipping the pipes around like red posted above^^^ so it won't melt the hood.
P.S. Donuts are hard to do with atv tires so I WILL be swapping over the turfs just for like a day or two. | |
| Subject: Re: LMM's OFF-ROAD MOWER January 13th 2014, 8:02 pm | |
| I haven't been doing much lately, because of the RMWS. BUT! I did romp it a lot in the snow, I also jumped it once (all 4 tires off the ground!). I have a mysterious flat tire in the front... I think it is because the tire was compressed when I got it, that may have screwed up the bead. So I gotta deal with it until I get a tube. The pipes sound real good, they have that AWESOME crackle when you let off the throttle real quickly and the roar when you mash it.
Other than the tire problem it preforms good. | |
the craftsman mudder New Member
Age : 26 Join date : 2014-01-13 Points : 3987 Posts : 20 Location : North Carolina
| Subject: Re: LMM's OFF-ROAD MOWER February 25th 2014, 2:51 pm | |
| Nope nothing changed. But some stuff is starting to go into the void, exhaust threads are stripped in the block from apparently not having enough of a brace on the exhaust. Front left tire got a slow leak (need a tube), the bushings in the axle are crap, frame cracked again,steering slop got worse (probably from popping wheelies), and the shifter got too much slop. I thought about putting a new frame under it with all the same stuff (ie: sheetmetal, tires, trans, etc). BUT, my dad says I should keep it the exact same and drain all the fluids out of it and put it in the barn with a "Finished (for now)" sign on it, and do another off-roader. I don't know though... | |
Age : 57 Join date : 2013-12-21 Points : 4805 Posts : 744 Location : Salem Illinois
| Subject: Re: LMM's OFF-ROAD MOWER February 25th 2014, 3:23 pm | |
| Just keep at it brother, a little at a time. Brace the frame with some more steel, support the shaft and tighten the linkage on the shifter... Just an hour a day, step by step.... It'll get there! | |
Age : 23 Join date : 2014-01-22 Points : 4571 Posts : 546 Location : north carolina
| Subject: Re: LMM's OFF-ROAD MOWER June 23rd 2014, 9:10 am | |
| so LMM has anything new happened to it i have seen it in the backgrounds of other pics and was wanting to see more of it | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5761 Posts : 1408 Location : Galway NY
| Subject: Re: LMM's OFF-ROAD MOWER June 23rd 2014, 12:14 pm | |
| - willis923 wrote:
- he has been slacking on his threads lately.. ffs
And to think that I was just about to reply to this anyways... Thanks Willis! Well, as I have been busy with the build off rally I haven't touched this since about December . Hopefully I can revive it when the build off is finished. It has been a workbench. Sorry about the lack of updates on this. | |
| Subject: Re: LMM's OFF-ROAD MOWER June 23rd 2014, 12:16 pm | |
| - LAWN MOWER MUDDER wrote:
And to think that I was just about to reply to this anyways... Thanks Willis! lol, i'm just pokin. | |
