This oughta be interesting! What modifications do you plan to make to the engine to deal with the air boost?
when i rebuilt my carb i started to think about the smog pump supercharger idea well while i had the carb apart i did a few internal mods bigger jets so it does run rich right now as idle and a little bit rich at max throttle so this should fix it going lean with 6psi running thru the engine nd the reason for my stock heads insted of my shaved ones is the compression if i keep the shaved heads i would of blew the head gasket in less then a hour thats why im running stock heads but i did have the engine ported and polished a few weeks ago i had a pro look at it and he told me 40hp is what im pushing with these mods if i added a turbo and got billet rods and a flywheel i could push 50+hp but he recommended the smogpump idea because i already have a bigger cam in the engine and i might run a small heater core for a intercooler (since im going with the smogpump he sees my HP being around 45-47HP depending on the boost 47hp at 8psi 45 at 5psi)
MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4752 Posts : 477 Location : Haddock,Georgia
well i had to do somework on that smogpump come to find out 2 of the rollers on the bearing on the front where seized so i had to fill it up with oil and let her sit then i drained it and turned it over and it worked like a new pump it even feels like its blowing more air out since i unseized the bearings lol did a little test fitting i got alot of leg room still if i do it like this and that golden piece is the output so the tubing/pvc will get hooked up there then plumbed into the intake i couldnt shut my hood so couldnt get a good look at it with the hood closed i might relocate my gastank under my seat and put the smog pump there chances of that are slim but this is how ill run the intake hose that the pump needs and ima run theout let hose to pvc then to the intake
mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4597 Posts : 327 Location : Rindge, NH
i really dont have anywhere to relocate my fuel tank so i think it might stay where it is also ima run 98 fuel in it to this should be the best running opposesd twin out there lol
Age : 25 Join date : 2013-04-05 Points : 4965 Posts : 661 Location : New Smyrna Beach,Fl
Well i got around to starting up sarge you can really hear the cam in this video and it is runnign a bit rich at idle so it wanted to stall but hat wont happen when i get the supercharger on it the rev was only half throttle couldnt go to 4500 because dont have a tach hooked up
MowBandit Member
drive sarge today and noticed alot is wrong with the steering the max speed was 25mph and the steering with the rubber bushings suck so im gonna work on it some more and grease the bushings
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7321 Posts : 2914 Location : Ontario Canada
got to drive sarge with the new frontend for a little bit and i thought i was in 5th but i was only in 3rd the whole time so i do 25mph in 3rd so i wonder what i could do in 5th but my i can only go into 3rd it wont let me go into 4th or 5th so im thinking my shift linkage is messed up :/
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
Pshh if you had custom shifting linkage like mine you wouldn't have a problem! LOL
MowBandit Member
nah its not like that its something to do with my shift keys again ive had nothen but probloms with them :l
What's with the shift key issue? Are the inside bores of the gears good? Shifting on the fly? Slop in the shafts?
last year i ran sarge to hard i was pulling a atv trying to pull start it i got up to 5th then he reseased his clutch and the atv almost started and i down shifted to 4th without usig my clutch and the transaxle seized then it broke loose when i floored it and it stopped workin period i borke a shift key off in 4th and the bore is really messed up like just not work fixing it at all when the shift key broke the key litarly did a 360 spin inside the bore so 4th has never worked the same lol
MowBandit Member
i didnt feel like taken pics so i took video of rebuilding sarge's frontend after i took her for a romp over some logs and the frontend wanted to twist a bit so lol the problom was i for got to tighten it up all the way (learn form your misstakes) so i took off the front end with the help from my freinds and we got the front end fixxed also i did what doc told me to and i greased up the front axle:) please dont mind my messed up hair XD
Assuming it's a Peerless (is it?) I strongly advise against shifting on the fly, especially downshifting. I know some guys will say it's okay, I say it ain't. Especially when you have a heavier machine, bigger tires, greater speeds, etc. There is no synchro mechanism, it's just simply not designed for that...
nah its no peerless its a old 4360 spicer i always shift on the fly but down shifting is something i dont do much unless im leaking oil then yea ima risk the transaxle and downshift fast lol
We shift on the fly, but are careful about not doing it under load, IE upshifting without clutch or downshifting at all. The shifter keys do tend to wear out unfortunately.
My build (Chaos is one of 3 built like this) Chaos Build
not much of a update im still in flordia about 30mins from alabama and well mudqueen messaged me on FB wanting to know if she could drive sarge around while im not there the deal was to take it easy and keep the tank full well first off some hoodrat tried to steal all the wiring off sarge so that had to be fixxed (thanks to my dad) and well from what she told me she went down a hill in he backwoods and smacked a tree and now she says the steering has a lot of play i asked here if anything looked broken she replyed nope just the front axle backmounting plate looked a little bent -_- so when i get home monday ill take pics of this damage and what not im praying that its fixxable if not ill have to find a parts poulan and redo the whole front end (im not paying for it)
