| Will a 11x4-5 tire fit on a 5-4.50 rim? | |
isaiahwitters New Member
| Subject: Will a 11x4-5 tire fit on a 5-4.50 rim? May 8th 2013, 10:00 pm | |
| im getting 11/4/5 tires for my racing mower but can only fin rims that are 5/4.50 will this work or will i break the bead on a turn and thses are my front tires and wheels | |
| | | Doug Site Owner
| | | | Doc Sprocket Site VIP
| Subject: Re: Will a 11x4-5 tire fit on a 5-4.50 rim? May 8th 2013, 10:31 pm | |
| Let's examine this: your new tires are 11" diameter, 4" wide, 5" diameter rim. Your rims are 5: diameter, 4 1/2" wide. Perfect.
(unless I've misunderstood your numbering. tires are 11x4.50-5, yes?) | |
| | | Guest Guest
| Subject: Re: Will a 11x4-5 tire fit on a 5-4.50 rim? May 8th 2013, 11:51 pm | |
| - Doc Sprocket wrote:
- Let's examine this: your new tires are 11" diameter, 4" wide, 5" diameter rim. Your rims are 5: diameter, 4 1/2" wide.
Perfect.
(unless I've misunderstood your numbering. tires are 11x4.50-5, yes?) I'm with Doc on this one - IF those numbers are meaning dimension, then yes it will work quite nicely. Perfect size, as he said. |
| Who is online? | In total there are 7 users online :: 0 Registered, 0 Hidden and 7 Guests
