| Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER | |
+7Murray modder crafsmankiller truckin42 Kel Thunderdivine RCG Cr8zyB0b 11 posters | |
Chopperhed Moderator
| Subject: Re: Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER April 22nd 2013, 10:30 pm | |
| A crossover pipe helps with bottom end torque.
RUnning without one maximizes top end horsepower.
Most twin and multi cylinder bikes run one, some run a resonance chamber.
Age : 29 Join date : 2011-08-04 Points : 6403 Posts : 1434 Location : east dublin georgia
| Subject: Re: Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER April 22nd 2013, 10:39 pm | |
- prometheusEDI wrote:
- truckin42 wrote:
- Yeha he said somthing like a 22hp oppozzed.
There's a small diff between a v twin and appossed LOL Quite a lot indeed, tho I see many mistake em and mix em up. I want one so I can have dual stacks and act like a motorcycle haha Dual stacks with a bridge, what I've read about twins it seems they like to share exhaust, like the two | | are joined like |-| they like to "talk" to each other. Lol Yes. A crossover pipe helps keep just a little backpressure in the system. Always need just a little anyway. Want to make it 'cackle' like a Harley? Use glass-pack mufflers for a Volkswagen Beetle. Trust me Like a x-pipe in a car. Sounds better too. To many quotes too lol is there a record/limit? if there is, your not close to it lol i seen another one that had alot more | |
| | | Cr8zyB0b Member
Age : 28 Join date : 2013-01-02 Points : 4396 Posts : 30 Location : England uk
| Subject: Re: Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER April 23rd 2013, 4:09 am | |
| Thanks for your opinions on the engine and it looks like you all have said the 22HP opposed twin briggs and that is what I am going to use.. The exhaust I will make a crossover exhaust so I will get bottom end torque and don't actually have to blow it up to get out of a mud pit.. I have spoke to a friend which is willing to sand blast my mower chassis to remove the rust and old paint,and etch primer it so it won't rust again he also said that he wouldn't mind doing it for FREE... The steering will stay stock for the moment but will be changed when I make the front axle longer to fit bigger tires on the front so if any one has any idea on direct steering that would be great I also have another decision on that front should I have handle bars with a thumb throttle or a steering wheel with a gas pedal.. Also pulley ratios have come to mind and to be honest I don't have a clue about them.. | |
Age : 49 Join date : 2012-04-23 Points : 5704 Posts : 1091 Location : Galion, OH
| | | | redlinemotorsportts Moderator
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
| Subject: Re: Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER April 23rd 2013, 7:13 pm | |
ill keep it going! Haha, and yea like copperhead said, you need backpressure. I heard that you can warp valves with no exhaust | |
| | | truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5506 Posts : 1070
| Subject: Re: Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER April 23rd 2013, 7:25 pm | |
ill keep it going! Haha, and yea like copperhead said, you need backpressure. I heard that you can warp valves with no exhaust Yeah thats why i have mufflers on my mower for backpessure. I think it is true that you can wrap your valves. | |
Age : 58 Join date : 2012-10-14 Points : 5257 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER April 24th 2013, 2:52 pm | |
ill keep it going! Haha, and yea like copperhead said, you need backpressure. I heard that you can warp valves with no exhaust Yeah thats why i have mufflers on my mower for backpessure. I think it is true that you can wrap your valves. You may or may not warp them, but you will definately burn the exhaust valve seat | |
| Subject: Re: Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER April 24th 2013, 3:17 pm | |
ill keep it going! Haha, and yea like copperhead said, you need backpressure. I heard that you can warp valves with no exhaust Yeah thats why i have mufflers on my mower for backpessure. I think it is true that you can wrap your valves. You may or may not warp them, but you will definately burn the exhaust valve seat back pressure is always good | |
| Subject: Re: Mc CULLOCH SPYDER REAR ENGINE SWAMP/MUD MOWER April 24th 2013, 3:43 pm | |
ill keep it going! Haha, and yea like copperhead said, you need backpressure. I heard that you can warp valves with no exhaust Yeah thats why i have mufflers on my mower for backpessure. I think it is true that you can wrap your valves. You may or may not warp them, but you will definately burn the exhaust valve seat back pressure is always good I heard you can also burn your valves. Yes backpressure helps your motor run and last longer. | |
| Who is online? | In total there are 42 users online :: 0 Registered, 0 Hidden and 42 Guests
