Some people say cheap is good... me I say, you get what you pay for. Find an E3 spark plug if you can... you will not be disappointed. Just bring your old spark plug with you so you can match size etc, sometimes the parts dealers don't know and give you a plug meant for something else entirely. But the E3 usually holds up to it's guarantee
dylansrockinrigs Member
Age : 25 Join date : 2012-02-28 Points : 5032 Posts : 306 Location : Silk Hope N.C.
bringing the old spark plug is no use... when i pulled it out of the motor the porslen was cracked all to its and the metal rod was bent and broke.
OK, in that case, if you can get a part # off the spark plug, it helps. Or, when you do go shopping for a plug take a mental picture of the plug you got out of there... best of luck!
