| New build, looking ideas | |
TheEquineFencer Member
Join date : 2013-02-19 Points : 4415 Posts : 90 Location : Farmville,NC, USA
| Subject: New build, looking ideas April 7th 2013, 8:01 am | |
| I finally got a day off during daylight hours to get by to pick up what I'm sure is an 820 style Peerless rear end. It has the 1 inch axles. I'll get it washed off and see if I can fins some numbers on it to see what I have. I got it home and finnaly got the rusted out drive pulley off. I used a torch to "uncover" the snap ring to remove the ring. I heated it up and the metalmites let go of it. I had to cut what was left of the pulley off down to the hub bushing, then used a puller to remove the keyed part. I'm wondering what pulleys, belt size and what to do for gearing. I'm going to build something like a 'Gator from scratch for use around the farm. I'll need some bottom end power for low speed pulling but want the top end speed for when I really want to go somewhere. The engine choices are a fairly new OHV 15.5 Briggs from a Murray or Bolens mower I salvaged or a 18 HP OP Briggs That I know used to run. I'm leaning more towards the OHV engine. I'm going to do a little measuring this faternoon to see how wide I'll build the thing, I'll measure the neighbors "mule" and use that as a guide. I plant to build a set of rear adapters for the axle from a set of S-10 axle flanges, 5 lug Chevrolet bolt pattern. I'm thinking for gearing to use the same size pulley on the rear end as the engine. What are the deminsions I need for that pulley? How hard is it to install a gearset in the rearend to pick up the top end speed? | |
| | | xxXMowerdudeXxx Established Member
| Subject: Re: New build, looking ideas April 7th 2013, 9:59 am | |
| I found the numbers from the rear end, it's a 820 037 Peerless 1064 1248. So what does this mean? is there a thread with how to go through one of these? I noticed the input shaft has someplay in it like the bearing is worn some moving it left to right and it has some play when you pull up on it too. Will new bearings fix this? | |
Join date : 2012-12-21 Points : 6537 Posts : 2101 Location : Norway, Europe
| Subject: Re: New build, looking ideas April 7th 2013, 10:11 am | |
| - TheEquineFencer wrote:
- LOL, I was just looking at that thread.
Yea, tho that link/post should be in the tranny topic and not in general section. | |
| Who is online? | In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
