 low idle issues
5 posters
Thebuilder92
low idle issues Empty
PostSubject: low idle issues   low idle issues Icon_minitimeWed Mar 27, 2013 11:31 am
I cant seem to get my briggs to idle when i throttle all the way down. i've cleaned the carb, and im debating whether or not to mess with the jets. any ideas?
PostSubject: Re: low idle issues   low idle issues Icon_minitimeWed Mar 27, 2013 5:07 pm
Will it run if you throttal it up?
PostSubject: Re: low idle issues   low idle issues Icon_minitimeWed Mar 27, 2013 5:49 pm
Should be an idle adjustment screw on the carb somewhere. If you turn it out a bit you should idle fine. Might take some tinkering.
Murray modder
Murray modder
PostSubject: Re: low idle issues   low idle issues Icon_minitimeWed Mar 27, 2013 6:04 pm
If you get off the tractor and use the main arm to make it idle? sounds to me like your missing a spring.
mudmonkey06
mudmonkey06
PostSubject: Re: low idle issues   low idle issues Icon_minitimeWed Mar 27, 2013 8:47 pm
there is around 2 screws on the carb just adjust those and you will be fine
Thebuilder92
PostSubject: Re: low idle issues   low idle issues Icon_minitimeSun Mar 31, 2013 9:53 pm
Thanks guys! I played with the jets and they all have their springs. i also cleaned the carb really well and it seems to idle better, but not the greatest. ill keep playing with it and see what happens!
PostSubject: Re: low idle issues   low idle issues Icon_minitimeSun Mar 31, 2013 9:54 pm
Ok keep us updated.
low idle issues
» 12.5 HP B&S Starting Issues.
» Starter issues!!
» Domain issues...
» belt issues
» belt issues
