When i press my push button to start the engine, the gear just spends doesn't go up to start the engine! How do I fix this??? Btw its 23 hp Kohler pro vtwin
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5764 Posts : 1408 Location : Galway NY
work the bendix free with some pliers or something, apply some WD40 to help out, and after its free, lube the shaft with some white lith grease. also make sure the battery is full. it has to turn a certain speed for the bendix to engage
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5155 Posts : 1068 Location : New jersey
