 MTD starter gear
2 posters
Normandybrit
MTD starter gear Empty
PostSubject: MTD starter gear   MTD starter gear Icon_minitimeJuly 18th 2024, 7:02 am
MTD B&S 12.5 motor.
Are there different starters for the single cylinder motors? Recently I've managed to strip the teeth from two starters. Given that my machines are kept going by me grabbing anything that will keep them going. I wondered if there's some kind of mis-match between the ring gear and the starter dog?
PostSubject: Re: MTD starter gear   MTD starter gear Icon_minitimeJuly 18th 2024, 9:59 am
There are some with 16 tooth plastic gears, and some with 14 tooth metal if I am not mistaken.
Got the model/type/code for that engine?  Maybe we can help decipher the correct one. Should be stamped up by the spark plug or on a plate by the flywheel.
MTD starter gear Sig115PROJECTS:
MTD starter gear Sig214MTD starter gear Sig314
Normandybrit
PostSubject: Re: MTD starter gear   MTD starter gear Icon_minitimeJuly 18th 2024, 11:25 am
That would explain things! The current one was plastic and has absolutely shreaded.  Worked ok for a coupleof weeks too....MTD starter gear Img_2010
PostSubject: Re: MTD starter gear   MTD starter gear Icon_minitimeJuly 18th 2024, 4:30 pm
AYE... that was helpful. Briggs shows 3 possible starters, plastic, steel and aluminum gear. Do you think you have the original starter?
The flywheel, is it's gear Aluminum or Steel. Aluminum, it takes a plastic gear. If steel, then the steel gear is my understanding.
JB_4x4 likes this post
Normandybrit
PostSubject: Re: MTD starter gear   MTD starter gear Icon_minitimeJuly 19th 2024, 10:06 am
It's a steel flywheel. So I'm going to have to hunt out a metal starter dog. Many thanks for your input on this!
PostSubject: Re: MTD starter gear   MTD starter gear Icon_minitimeJuly 19th 2024, 5:10 pm
That has been my understanding.
MTD starter gear
» outlaw lawn crafts dirty dynamark mud mower! [2016 Build-Off Entry]
»  Briggs 14 hp vert shaft IC engine Starter drive gear problems
» Starter tore off, need fix
» Starter issues!!
» Starter issues
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: Starting and Soleniods-
