 KILL SWITCH PROBLEMS! i need help
Tanner306
KILL SWITCH PROBLEMS! i need help Empty
PostSubject: KILL SWITCH PROBLEMS! i need help   KILL SWITCH PROBLEMS! i need help Icon_minitimeMarch 17th 2013, 11:03 am
i have and old wheel horse mudding lawnmower and i put an old 12.5 hp briggs in there i wired it up and i was all set. RECENTLY i have been having problems with this. i CANT SHUT IT OFF!!! i just put one wire to the coil from the switch and the other wire from the switch i put to ground, and now i cant go anywhere with out a screwdriver to pull of the air filter. please help me Question
xxXMowerdudeXxx
PostSubject: Re: KILL SWITCH PROBLEMS! i need help   KILL SWITCH PROBLEMS! i need help Icon_minitimeMarch 17th 2013, 11:40 am
welcome to the form, where in Wisconsin are you?
Last edited by xxXMowerdudeXxx on March 17th 2013, 11:49 am; edited 1 time in total
CornishMorgan
PostSubject: Re: KILL SWITCH PROBLEMS! i need help   KILL SWITCH PROBLEMS! i need help Icon_minitimeMarch 17th 2013, 11:47 am
The first thing I would check would be the switch, check that it is working properly, You may have fitted a old switch that works but is on its way out or it could have burnt out the contacts inside. Try jumping the two terminals on the back of the switch and see it the engine shuts down. If not then you could have a bad ground connection. Try taking the coils ground wire off and cleaning the terminals with some light grit sand paper. Also try bypassing the switch for the time being and try shutting the engine down by holding the coils ground wire directly against the frame (be careful of the high voltage and of the sparks if you have fuel near by).
A side note: This should be in the Electrical category.
» Kill switch, lights, regulator, diode?
» Ignition switch help
» No spark after replacing key switch please help!!!
» wiring up a modern key switch
» Seat safety switch
