| Welding galvinized metals | |
+5Thunderdivine TheRainbowBoxer Doug gearheadmike Mark288 9 posters | Author | Message |
Mark288 Member
Age : 27 Join date : 2013-01-20 Points : 4400 Posts : 48 Location : Southern Wisconsin
| Subject: Welding galvinized metals March 7th 2013, 9:56 am | |
| Hey guys. When you weld galvinized steel what kind of prep do you do? I hear you get real sick from them fumes. Any ways to still weld with galv? Thanks | |
| | | gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5207 Posts : 392 Location : west chazy ny
| Subject: Re: Welding galvinized metals March 7th 2013, 10:08 am | |
| what i did befor was grind the spots im welding and place a fan blowing away the smoke/fuems but best to do it outside or on a slightly windy day. | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7783 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Welding galvinized metals March 7th 2013, 10:11 am | |
| I hear drinking lots of milk before and after can help you.
Best practice is to try and grind off the zinc before welding, and to weld in a well ventilated area. If you weld outside with a box fan blowing away from you so the fumes cant reach your face you should be fine. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Age : 49 Join date : 2012-04-23 Points : 5702 Posts : 1091 Location : Galion, OH
| Subject: Re: Welding galvinized metals March 7th 2013, 10:15 am | |
| The only problem with using a fan to blow the fumes away is it makes it hard / impossible to weld using gas shielded mig. We never really had any issues with welding galv. Just keep your head out of the smoke as much as possible. | |
Join date : 2012-12-21 Points : 6544 Posts : 2101 Location : Norway, Europe
| | | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 5165 Posts : 745 Location : The Wyo-Braska Panhandle
| | | | Mark288 Member
| | | | Doug Site Owner
| Subject: Re: Welding galvinized metals March 7th 2013, 3:59 pm | |
| - Mark288 wrote:
- I didnt know there was one in the faq sorry bout that
Its always a good idea to check the FAQ or use the "Search" function before posting a question. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Murray modder Member
Join date : 2012-11-23 Points : 4802 Posts : 356 Location : Somewher in Va
| Subject: Re: Welding galvinized metals March 7th 2013, 9:44 pm | |
| Zinc burns, Best way I've done it coming from an ironworker I aprrenticed with. "Get a 55 gallon drum, get yourself a nice hobo fire going, drop your galvanized peice in and run." | |
| | | W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5252 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Welding galvinized metals March 7th 2013, 9:53 pm | |
| i am just going to give my 2 cents, where i work when we weld galvanized (the only galvanized metal we normally weld are caster wheels) we will use are fume extractor and a mask or stay near to a door and again wear a mask. On mobile jobs normally the best we can do is just wear a mask and since we are stick welding the wind, etc. will normally blow the fumes away. but if you are going to weld galvanized id recommend taking little breaks from welding and let the shop air out your working in or the general area your working in.
Join date : 2013-06-01 Points : 4811 Posts : 578 Location : West Virginia
| Subject: Re: Welding galvinized metals July 17th 2013, 2:31 am | |
| DO NOT BREATH IN GALVANIZED FUMES!! Been there done that.. was welding pipw up for a guy and thought nothing of it and aas light headed felt like I was going to die for 2 days.. its some nasty stuff | |
