 Idea for The easiest 4x4+4WD
Marines2621
crafsmankiller
Jordan
Chopperhed
Tractor Man Jeff
12 posters
Go to page : Previous  1, 2
dylansrockinrigs
Idea for The easiest 4x4+4WD - Page 2 Empty
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 8th 2013, 5:46 pm
you could build something like this
Chopperhed
Chopperhed
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 8th 2013, 7:17 pm
Thunderdivine wrote:
I got 4 of these laying around but only two identical (same gearing).
But im planning on makin a tracked autonomys robot mower of those two identical.
You could use 1 of your unmatched ones to feed into a geared transaxle and have a multi range geared hydro system
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 11th 2013, 12:44 pm
Great idea bounce
xxXMowerdudeXxx
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 11th 2013, 3:31 pm
Interesting
dked41
dked41
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 12th 2013, 12:54 pm
Case lawn tractors use hydraulic drive on their diffs, no pulleys or belts, just hoses. You could articulate one with no problems. You just need a pump to supply hydraulics for the drive motors and steering. Case mowers are out there, and can be found cheaper than Cub Cadets. I have several donors but no time or shop space to build one.
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 17th 2013, 5:49 pm
This is what i ment, But with two trannys and with the pivot point exactly on the center of the pulleys. Meaning you dont have to use more pulleys and stuff.
Idea for The easiest 4x4+4WD - Page 2 5fb1b1868251adc80322ed03601f3848_zps85baf2a8
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 17th 2013, 5:55 pm
or more like this.
Idea for The easiest 4x4+4WD - Page 2 4x4_zps3edd668a
Murray modder
Murray modder
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 17th 2013, 6:22 pm
Why not grab two zero turn transissions, mount em on the front and, IT WOULD TURN LIKE A TANK!!!
Chopperhed
Chopperhed
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 17th 2013, 8:04 pm
Personally, I'd go with a 4 wheel steer setup, like the old full size Case 4wd tractors.
Need two RWS diffs to do it.
They could crab steer when you needed to
PostSubject: Re: Idea for The easiest 4x4+4WD   Idea for The easiest 4x4+4WD - Page 2 Icon_minitimeMarch 18th 2013, 1:15 pm
I would never get four hydros of the same gearing it just cost to much. Even hydraulic.
But maybe with two transaxles. Time will show:)
» just getting an idea for it
» my 6x6 idea for anyone that wants to know.
» Any idea on what this is?
» i have a REDNECK idea
» idea for 4WD
