| Idea for The easiest 4x4+4WD | |
+8Marines2621 Doug truckin42 crafsmankiller Jordan Chopperhed Tractor Man Jeff Thunderdivine 12 posters |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6545 Posts : 2101 Location : Norway, Europe
| Subject: Idea for The easiest 4x4+4WD February 19th 2013, 4:47 pm | |
| So I've been thinking... Anyone remember how we made our first carts? Well, we made the steering from two wheels connected to a wooden plank, and for it to turn we used only one center hole in the plank... So. How about you take two rear or std transaxles, and mount the front one in a tray so it can pivot, turn side to side by one point only?! If you want 4WD steering you do this to both axles, so in a turn it would look like / \ for 4WD steer, watched from above, anyone done this before? I'll draw up a sketch later on if it was poorly explained | |
Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 5015 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: Idea for The easiest 4x4+4WD February 19th 2013, 5:33 pm | |
| Not really like that but kind of just easier, since you would want to make the pivot point on the same point as the pulleys, meaning all you need is, engine, two belts and two axles. So when you turn it keeps the output shaft on the turn point. Need a sketch lol
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5256 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Idea for The easiest 4x4+4WD February 19th 2013, 5:37 pm | |
| It can be done, but there are problems. You need to have really long axles or a really narrow tractor.
allowances have to be made for the axles to swing through their arcs. | |
| Subject: Re: Idea for The easiest 4x4+4WD February 19th 2013, 5:57 pm | |
| I got ya. Once again, the linkage would most likely get ya. I would see it working, but how would you mount the engine? I think someone with a bunch of tractors laying around should try this. | |
| Subject: Re: Idea for The easiest 4x4+4WD February 19th 2013, 6:17 pm | |
| Mount it original spot, then you'll need two more pulleys if not mount it midway like 2/3rd, ya someone with many parts should try this | |
| Subject: Re: Idea for The easiest 4x4+4WD February 19th 2013, 6:19 pm | |
| That way you wouldn't need an all steer transaxle. I still want to make an articulated tractor. | |
Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5357 Posts : 170 Location : Ontario Canada
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 11:33 am | |
| the easiest way to do it in my opinion is hydraulic drive, ive seen a few lawn tractors over the years that have an engine running a hydraulic pump and then 2 lines going to the controls then to the rear axle getting 2 of those axles set up to articulate like the one in the picture would be easy because you can just split the lines after the pump and run both axles at once and for steering just get a power steering box off a truck and run it through the pump aswell, so it will work like a truck does when the machine is off there will still be steering but stiff and when its running the pump will make it pretty easy | |
crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4895 Posts : 412 Location : livingston texas
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 12:28 pm | |
| seems pretty straightfoward. but how would you mount the transaxle to keep the pulley in the same spot and still let it rotate? | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5505 Posts : 1070
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 1:02 pm | |
| Sounds like an idea that would work but how would you keep the belt from coming off the pully. | |
Jordan Member
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 3:30 pm | |
| - Jordan wrote:
- the easiest way to do it in my opinion is hydraulic drive, ive seen a few lawn tractors over the years that have an engine running a hydraulic pump and then 2 lines going to the controls then to the rear axle getting 2 of those axles set up to articulate like the one in the picture would be easy because you can just split the lines after the pump and run both axles at once
and for steering just get a power steering box off a truck and run it through the pump aswell, so it will work like a truck does when the machine is off there will still be steering but stiff and when its running the pump will make it pretty easy Hydraulic motor wasn't an option tho when I wrote this, tho I agree, easiest but expensive. | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7784 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 3:49 pm | |
| A hydraulic piston for steering and a PTO drive hydro (like old Cubs) would work perfect for this scenario. The steering wheel could control the piston for your steering, and the pivot point could be solved by using a universal joint.
Running belts might be tricky through the midsection as there is a good chance of rubbing somewhere. Having the front axle driven by belt and off that axle pulley a RAGB running to a Ujoint then to another RAGB for the rear would probably work perfect. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 3:51 pm | |
| - Doug Fackler wrote:
- A hydraulic piston for steering and a PTO drive hydro (like old Cubs) would work perfect for this scenario. The steering wheel could control the piston for your steering, and the pivot point could be solved by using a universal joint.
Running belts might be tricky through the midsection as there is a good chance of rubbing somewhere. Having the front axle driven by belt and off that axle pulley a RAGB running to a Ujoint then to another RAGB for the rear would probably work perfect. That ain't easy.... | |
Jordan Member
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 3:53 pm | |
That ain't easy.... probably easier then trying to rig up pulleys and belts though, and the less belts in the system the more durable it is | |
Doug Site Owner
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 3:57 pm | |
| I wouldnt say not easy more than expensive and time consuming. It would be a lot easier though than having to figure out how to run your belts and pulleys so you dont get any rub wear or slack. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Marines2621 Member
Age : 27 Join date : 2012-12-31 Points : 4585 Posts : 215 Location : Mountainburg, Arkansas
dylansrockinrigs Member
Age : 25 Join date : 2012-02-28 Points : 5040 Posts : 306 Location : Silk Hope N.C.
| Subject: Re: Idea for The easiest 4x4+4WD March 7th 2013, 7:25 pm | |
| - dylansrockinrigs wrote:
- I tried to upload a pic if it didnt work click the link below \/
Yeah this might work. | |
| Subject: Re: Idea for The easiest 4x4+4WD March 8th 2013, 8:30 am | |
| I got 4 of these laying around but only two identical (same gearing). But im planning on makin a tracked autonomys robot mower of those two identical. | |
