| wheel wobbles | |
maxrpm1224 New Member
Join date : 2013-01-08 Points : 4340 Posts : 5 Location : maryland
| Subject: wheel wobbles January 16th 2013, 4:22 pm | |
| when i put 22x10 kenda tires on the rear of my murray it was awsome but over the past few days ive notice my 18x8 that is up front started to wobble not a little bit but like crazy its my front right its and 8in rim but theyre old like from the 70s im hoping its an easy fix. tell me if its happened to your or you know how to fix it thanks | |
| | | Chopperhed Moderator
| Subject: Re: wheel wobbles January 16th 2013, 4:47 pm | |
| Something is worn out, probably a tie rod, but possibly the spindle and/or bushing. | |
| | | gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5203 Posts : 392 Location : west chazy ny
| Subject: Re: wheel wobbles January 16th 2013, 7:23 pm | |
| does the front have bearings in the wheel or no? could be a lack of luberication or worn tie rod and or where the spindle go's through the axle. or the axle piviot point could be loose | |
| Subject: Re: wheel wobbles January 16th 2013, 8:20 pm | |
| The rims could be worn where they ride on the spindle - rear rims werent designed to spin on an axle - theyre ment to be solid mounted and spin with the axle.
The one spindle could be worn slightly also on that one side causing the wobble. Best bet id say is to save up for some bering hubs and different rims or a set of front 8" rims off a GT mower ( which are larger).
Or have the wheel fall off unexpectedly...
| Subject: Re: wheel wobbles January 16th 2013, 9:19 pm | |
| ok thanks i think it just a lack of lube or something its not the whole spindle moving its just the wheel ill work on it thanks | |
| | | Tuffy55 Member
Join date : 2013-01-07 Points : 4366 Posts : 31 Location : MI
| Subject: Re: wheel wobbles January 18th 2013, 4:07 pm | |
| i bought 4 bronze bushings for my front tires and it rolls a heck of a lot better | |
| Subject: Re: wheel wobbles January 18th 2013, 8:04 pm | |
| figured out its a bent spindle i got to heat it and bend it back | |
| | | CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4233 Posts : 337 Location : Woodville Al
| Subject: Re: wheel wobbles April 9th 2014, 8:02 am | |
| The best thing iv come up with for front wheels are. I found a murray GT commurtial industrial. The front wheels are 8 inch by luke 6 inches wide and it runs a bushin for front applacation. I found bearings that replace the bushings. So as long as you keep grease in them. They work. And takes out alot of slack. | |
| | | | | wheel wobbles | |
| Who is online? | In total there are 35 users online :: 0 Registered, 0 Hidden and 35 Guests
