| Rustey Medal | |
+17MowBandit Doc Sprocket WellThatsSurprising redlinemotorsportts Murray modder mudmonkey06 richie thomas xxXMowerdudeXxx Thunderdivine Marines2621 TheRainbowBoxer Doug Chopperhed AcreFarm dangeroustoys56 CornishMorgan truckin42 21 posters |
truckin42 Veteran Member
| Subject: Re: Rustey Medal December 14th 2013, 8:25 pm | |
| Yeah I plan on rebuild it here soon. | |
Age : 26 Join date : 2012-10-04 Points : 5480 Posts : 1070
| Subject: Re: Rustey Medal December 20th 2013, 12:13 pm | |
| Well yesterday I put a battery in rustey and she fired right up and ran fine, backfired alittle but once it warmed up it did fine and also took her offroadin she doent do so good in mud does great in the wood runnin trees over and stuff but not good in mud gets stuck easy but it does get out slowely spinin tires the whole way. | |
| Subject: Re: Rustey Medal December 24th 2013, 9:31 pm | |
| Well rustey is getting rebuilt..goanna turn it into a tube buggy just need some idea on what to make it look like?..ill be starting the rebuild at the beginning of the month. | |
| Subject: Re: Rustey Medal January 2nd 2014, 5:26 pm | |
| Well started tearing rustey down for the rebuild..gonna make it a 2 sseater buggy. Once it completely taken apart im gonna start The build process | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6520 Posts : 2101 Location : Norway, Europe
| Subject: Re: Rustey Medal January 2nd 2014, 5:27 pm | |
| - truckin42 wrote:
- Well started tearing rustey down for the rebuild..gonna make it a 2 sseater buggy. Once it completely taken apart im gonna start The build process
You gonna enter the build comp. with it? | |
Age : 57 Join date : 2013-12-21 Points : 4782 Posts : 744 Location : Salem Illinois
| Subject: Re: Rustey Medal January 2nd 2014, 5:31 pm | |
| never too late... I'd love ta see what ya come up with!
| Subject: Re: Rustey Medal January 2nd 2014, 5:33 pm | |
| You can enter whenever you want until end date which is June 30. | |
| Subject: Re: Rustey Medal January 2nd 2014, 5:34 pm | |
| Well ill enter now..where do i go to enter | |
| - truckin42 wrote:
- Well ill enter now..where do i go to enter
3... 2... 1... HAPPY NEW YEAR!!! jocolor Now put down the champagne and pick up your tools! The ATLTF 2014 Build-Off Competition begins! So what do you need to do to get started? *Make a sign with the following info: "ATLTF 2014 Build-Off" "Password: Coccyx" Date of entry *Now- Take a picture of that sign with whatever parts/tractor you're beginning with! Start a new thread in this section (2014 Build-Off Contest Announcements And Entries) *Title Your Post with your name and project, ie: Doc's Mudder or Fred's Dragster or whatever. *In your thread- post the picture and a description outlining your build plans. Remember that your project must be LESS than 50% finished to qualify, so you need to convince us you have a lot of work ahead. Make it count! Once we've had a chance to go over your entry post and determine that you're good to go, your thread will be moved to the Contest Build Threads section. Remember to review the rules and make sure your sign has ALL the info on it, or your entry will not be qualified. Enter here; https://www.atltf.com/t3144-ready-set-build | |
| Rustey Medal | |
