I have a 78 dynamark that i did a full custom resto on..payed 10 dollars for it...sat for about 6 years and did not run..completely went through it..you have the right idea of using it for a stock puller...that tractor can outpull my Murray, Craftsman, and Simplicity...Ill post pics later when I get home of the resto.
SkiLLz New Member
Age : 32 Join date : 2013-02-12 Points : 4306 Posts : 8 Location : North
These are some of the resto pictures from the dynamark I rebuilt it was alot of fun! All around great tractor..its a great puller like I said..only thing with these is that the steering gears will wear causing some slop in the wheel and shorter turn radius. Just thought id post mine up so you can see that these rusty diamonds can actually shine if you put the work into them!! Hope you enjoy.
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7776 Posts : 3047 Location : Lebanon County, PA
Man I almost forgot about this. I have got into some rough times and the Dynamark has been turned into a racer. I am going to trade it for a 1970's Monkey Wards mini mower. The Dynamark does run and drive and everything but I havent swapped pulleys so its still slow. It now has a 11 horse Briggs.
