 Stronger LT1000 front end ideas
5 posters
jaymz_eric
Stronger LT1000 front end ideas Empty
PostSubject: Stronger LT1000 front end ideas   Stronger LT1000 front end ideas Icon_minitimeNovember 11th 2012, 9:51 am
hey guys if u seen my earliar post in the general tractor talk forum you know that i demolished my front end on the LT1000 with a bad case of the high speed death wobbles. Anyways, Im rebuilding her for strength now, so I was wondering what you guys did to beef up your front end on your LT1000's. Im wanting to use an I beam from a much older tractor, its 20 lbs heavier but uses a 1 inch pivot bolt and seems way more dependable....thanks guys!
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Stronger LT1000 front end ideas   Stronger LT1000 front end ideas Icon_minitimeNovember 11th 2012, 8:32 pm
I too also have a LT1000. I'm wondering the same thing. I'll be watching this thread as well.
PostSubject: Re: Stronger LT1000 front end ideas   Stronger LT1000 front end ideas Icon_minitimeNovember 12th 2012, 12:18 am
I mentioned in your other thread to possibly add some sort of shock to lessen axle travel quickness - wouldnt hurt to go overbord on the reinforcing either , possibly add some sort of flexing trailing arms to support it as well ( heim joints on steel bar).
I know on my future mod tractors theyre gonna be reinforced to the hilt.
matthew sidor
matthew sidor
PostSubject: Re: Stronger LT1000 front end ideas   Stronger LT1000 front end ideas Icon_minitimeNovember 12th 2012, 9:48 pm
My front end is pretty strong but I dont think you want yours up that high lol
Stronger LT1000 front end ideas 299369_417516598309775_878958284_n
Chopperhed
Chopperhed
PostSubject: Re: Stronger LT1000 front end ideas   Stronger LT1000 front end ideas Icon_minitimeNovember 12th 2012, 11:35 pm
Known in the industry as a steering stabilizer. Find an old worn out shock. It will help. If you have the bucks, get an aftermarket unit.
You are looking for a shock absorber ( minus the spring) with a 50/50 rate.
Any air cylinder with 1/8" ports will work too, just not well. Choke down the ports to 1/8 inch it will work better
Or go down the the local auto wrecker and grab a steering stabilizer of an old junker.
DT56 has it right.
That being said. There is no reason to drive at speed with an unstable front end.
Do a little research, and learn what it takes to build a solid unit.
» ideas on how to put a front bash bar on the front of this mower?
» How do I rebuild the front end on a craftsman LT1000?
» WANTED: 8 inch front wheels for Craftsman LT1000
» Front Suspension Ideas
» Crazy Front Suspension Ideas
