 Fast Craftsman steering help.
brownjon4
brownjon4
Fast Craftsman steering help. Empty
PostSubject: Fast Craftsman steering help.   Fast Craftsman steering help. Icon_minitimeAugust 7th 2012, 10:24 am
Hello i need some help with my craftsman mower. my steering wheel just free spins i know it has something to do with the gears but how do i fix it and what can i do to upgrade my steering so i dont run across this again? it goes 34 i would like it to go 40mph any tips and help on anything would be great.
briggs 123
PostSubject: Re: Fast Craftsman steering help.   Fast Craftsman steering help. Icon_minitimeAugust 9th 2012, 10:00 pm
there are bushings that go in it if you look hard you can see them thats your problem
brownjon4
brownjon4
PostSubject: hello    Fast Craftsman steering help. Icon_minitimeAugust 10th 2012, 12:58 am
I figured out my problem my tie rod broke. are you saying there are bushings in my steering gears . the only bushings i have came across are in my front wheels I am new at beefing up mowers so i am still in the learning stage . thanks for the advice
CornishMorgan
PostSubject: Re: Fast Craftsman steering help.   Fast Craftsman steering help. Icon_minitimeAugust 10th 2012, 6:57 pm
In the words of the Hyneman...Now there's your problem.
Razz
If you are planning to get your tractor to do 40mph, you will need to beef to your steering. Stock steering systems normally have way to much play in then and so travaling at 40mph will make your tractor wobble and go all over the place, I would be horrible to drive/ride (whichever it is for a tractor) and would be uncontrollable, not good.
Look around the whole steering system and I every little component, to see what you can strengthen. My fully stock tractor will take a few mods to be able to get to 40mph.
e.g. spindles, spindle brushing, tie rod, rack, pinion, steering column.
post pics is easy, get a photo sharing account like photobucket, upload pics and the site will give you IMG, URL, Email links, copy the IMG code and paste it into here.
PostSubject: Re: Fast Craftsman steering help.   Fast Craftsman steering help. Icon_minitimeAugust 10th 2012, 9:26 pm
And brakes - been there, done that and nearly had a trip in an ambulance more then once - going fast isnt all its cracked up to be when heading for a ditch at 30 some odd MPH and not being able to stop - i suppose im damn lucky i wasnt killed when the transmission locked up on my LT12 craftsman - i had only started out when it happened- if it were at top speed, id be lucky to be breathing.
Add a trans cleaning and new grease/oil as well to the list......and a helmet.
brownjon4
brownjon4
PostSubject: hello    Fast Craftsman steering help. Icon_minitimeAugust 11th 2012, 3:58 pm
thank you guys
» Question about Craftsman steering???
» Steering for 97 craftsman
» redneck craftsman power steering
» craftsman steering totaled
» Craftsman steering upgrade
