I used the deck lift adjustment shaft, welded a new, shorter handle to it. Welded a tab to it and attached the tab to the shifter arm on the transmission with a cut to length tie rod. Pretty simple really. I'll try to remember to take pics later, but right now the tractor is loaded in the truck for our Haspin trip!
Note: Stretch actually did the welding because I suck at it.
My build (Chaos is one of 3 built like this) Chaos Build
If you still have the stock deck handle, you can use it. You can even weld up the notches, then cut a new notch where neutral is, so it locks in neutral. We did this to one tractor.
A old steering tie rod works well, to go between transmission and deck handle. We've done 5 of them now, once you figure it out, not hard.
Post 3, pic one, shows a pic of a modified gear box, and a empty steering box.
Where the shaft goes sideways through the box, we drilled out to 1in, then welded in 1in OD x 3/4 ID bushings. Installed a lock collar against the large gear to tighten it against the small gear. Welded a short piece of 3/8's rod across the gap to keep it from spreading apart. Drilled and installed grease zerks on the new bushings.
Later on we welded the large gear to the shaft, keyways were getting loose on them.
Thanks man, it took us a long time to solve all (or most anyways) of the breakage problems. They are very reliable compared to the ones we used to run, where we would work on them for 2 or 3 hours for every hour of play.
That's a nasty work-to-play ratio. I'm glad you've got the major bugs hammered out now.
I've finally found the time to read through this thread completely. I think you've done a fantastic job of putting these machines together and making them work for you. I particularly like the alternative of swapping in a live axle instead of welding the diff. What's not there, can't fail.
I also appreciate the methods you used to address the shortcomings in the factory stock steering system. Guaranteed to take the ambiguity out of it, and it'll go where you point it.
Thanks for the props, you got some pretty nice work also.
Ratio was closer to 1 to 1 on the work/play, but still way more than we wanted. Not counting build time, new ones are much better. 5 tractors were ran 15-20 hours during haspin, and we had about 5 hours of repair time. Most of that was blown engine, and repairing a whoops inside of a couple transmissions. Also about 8 hours of work getting ready. So 75-100 hours of runtime to 13 hours of work. Not perfect, but getting much better.
Some have asked about the mods to improve the craftsman steering box. I took the pic in the thread and added some pointers. I goofed up on the pic, the lock collar is still there actually, the weld is on the other side of that gear. Oops.
We notched the rear fender piece so it would sit down over the frame, removed the framework that holds the seat up higher, and bolted the seat assembly right to the frame.
I really like the brake idea is it just a floating rotor? help in place by the caliper? Or it is welded to the axle or by a set screw or something.. Just curious
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5702 Posts : 1091 Location : Galion, OH
It took us years to make them relatively dependable. Now I can romp the crap out of it, jump it, race it, run it into things, etc, and it just keeps going.
I see how you notch the rear fenders and mount them directly to the channel frame but how is the seat mounted to the fenders? Does it just flap and not have the rear springs anymore? is the rear even held down?
