| | Craftsman 10/38 11/38 12/38 builds | |
+14redlinemotorsportts GenevaCustoms Doc Sprocket Craftsman Dude Creepycrawler LAWN MOWER MUDDER Chopperhed TheEquineFencer muddstir dangeroustoys56 TheRainbowBoxer dagr8tim gearheadmike Stretch44875 18 posters | |
dwcopple Member
| Subject: Re: Craftsman 10/38 11/38 12/38 builds May 4th 2014, 6:17 pm | |
| I see how you notch the rear fenders and mount them directly to the channel frame but how is the seat mounted to the fenders? Does it just flap and not have the rear springs anymore? is the rear even held down? | |
Age : 49 Join date : 2012-04-05 Points : 5667 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Craftsman 10/38 11/38 12/38 builds May 4th 2014, 6:38 pm | |
| We ran new steel across the top of frame, flat to the top edge, under the fender. One at the front has the hinge for the seat bolted to it. the other has the seat springs bolted to it. The seat can flip forward, which we do when it's raining and tractors are out, to keep seats dry. | |
| | | dwcopple Member
| | | | Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4385 Posts : 491 Location : Index, Washington
| Subject: Re: Craftsman 10/38 11/38 12/38 builds May 5th 2014, 11:22 am | |
| - TheRainbowBoxer wrote:
- We bypass the governor on all of our engines. We hook direct to the throttle. Stretch might have a pic of exactly how lying around...
Well git ta postin! | |
| | | | Angchor Member
| Subject: Re: Craftsman 10/38 11/38 12/38 builds May 6th 2014, 12:29 pm | |
| - Stretch44875 wrote:
- I've got a video up, check YouTube. Should be posted in engine section.
Thank you Stretch! You mean this one? https://www.youtube.com/watch?v=ldlIWhfc9xcThat was helpdul in the way that I need it to be helpful. I've already bypassed the gov on one, and hooked up my own foot throttle. I just like to see how people have done a variety of different hookups. I did mine without knowing anyone else had done them. Now I am curious about all the different ways, and the different affects, etc. I really like that foot throttle setup and the drilled nuts. I may have to steal that idea! | |
| | | | LAWN MOWER MUDDER Established Member
Age : 23 Join date : 2013-04-08 Points : 5175 Posts : 913 Location : Central Pa
| Subject: Re: Craftsman 10/38 11/38 12/38 builds May 30th 2014, 6:15 pm | |
| I think I remember you guys saying that your bumpers fit together nicely right? Like one is just a tad higher that the other for pushing purposes and stuff right? Could you get measurements of those so I could do that too on my rally? Then if I ever do make it to Haspin and my battery dies then I can be bump-started with ease by one of your tractors. | |
| | | dwcopple Member
| Subject: Re: Craftsman 10/38 11/38 12/38 builds June 12th 2014, 8:11 pm | |
| Stretch, after studying your reversed clutch pics, I was just wondering if you had any underside pics with the engine and trans installed so I can see the final routing. I see you switch the V for a flat on the clutch arm, but there was a flat next to the V on the original setup, do you ditch the second idler pulley and just use the flat clutch one only then??? Thanks in advance. | |
Age : 49 Join date : 2012-04-23 Points : 5667 Posts : 1091 Location : Galion, OH
| Subject: Re: Craftsman 10/38 11/38 12/38 builds June 21st 2014, 3:28 pm | |
| I can answer that one. We are running only one pulley clutches, no idlers. The Craftsman tractors we started with had only single pulley clutches stock. | |
| | | deaddave New Member
Age : 72 Join date : 2015-05-04 Points : 3471 Posts : 13 Location : Greensburg Indiana
| | | | Sponsored content
| Who is online? | In total there are 19 users online :: 0 Registered, 0 Hidden and 19 Guests
