 What is the best sprocket to gear ratio?
DieselDude666
What is the best sprocket to gear ratio? Empty
PostSubject: What is the best sprocket to gear ratio?   What is the best sprocket to gear ratio? Icon_minitimeMarch 30th 2012, 12:05 pm
Hey Guys. I'm building a monster mower, actually everything is done except the sprockets which I have some questions about. The mower used to be a husquavarna belt drive hydro. And with a hydro there is no clutch pulley so I thought to myself why don't I make it chain drive! But I need to know what ratio would work best. right now I am working on putting on a 30tooth (5 1/2'') sprocket on the front and the same on the back. What kind of torque/speed would that get me? It used to go like 5mph with a 4'' on the front and a 3'' on the back. Let me know
Thanks
DieselDude666
dked41
dked41
PostSubject: Re: What is the best sprocket to gear ratio?   What is the best sprocket to gear ratio? Icon_minitimeMarch 30th 2012, 1:12 pm
If you are talking about chain drive from engine to trans, running the same size sprockets front and rear would be slower than the 4" engine and 3" trans that was on it. Hydros don't like being overdriven like you can with a gear trans, speeding up the pump too much can wreck it .
DICE464
DICE464
PostSubject: Re: What is the best sprocket to gear ratio?   What is the best sprocket to gear ratio? Icon_minitimeMarch 30th 2012, 7:58 pm
yah if your going to do that do stock ratios otherwise you will burn out the pump
» Sprocket Ratio Calculators
» Gear Ratio's
» anyone lock a mtd fnr
» ? On belt ratio.
» Sprocket's Garage on FB!
