| I got a wild idea in my head | |
MSteele323 Member
Age : 50 Join date : 2010-04-09 Points : 5707 Posts : 267 Location : Little Rock Arkansas
| Subject: I got a wild idea in my head January 5th 2012, 12:09 am | |
| Ok, This will take alot of imagiatoin . But picture this take a Geo metro gut it out completely shave all weight as possible. Then find a opposed briggs with transmission . getting the idea. still hazy about the transmission . but make it a slow romper for fields Not for street use. feel free to add any ideas to this. This is what i have rattling in my head lately. Oh yeah it has to have all 4 atv WHEELS ON IT. | |
Age : 29 Join date : 2011-08-04 Points : 6403 Posts : 1434 Location : east dublin georgia
| | | | MSteele323 Member
| | | | Guest Guest
| Subject: I got a wild idea in my head January 5th 2012, 7:59 am | |
| just yank the engine and make an adapter plate for the stock clutch then power that from the twin |
Age : 45 Join date : 2010-06-28 Points : 5809 Posts : 511 Location : Southern WV
| Subject: Re: I got a wild idea in my head January 5th 2012, 10:54 am | |
| What's wrong with the stock motor, blown? The geo 3cyl is a popular swap into larger buggies like joyners and roketas. If you haven't found one yet, look for the elusive CVT transmission, or better yet, a subaru just which is basically a 4wd metro. If I could find a complete metro I'd strip it down and make a rear wheel drive 2-seat buggy out of it. | |
| | | dagr8tim Member
Age : 48 Join date : 2012-01-01 Points : 4944 Posts : 194 Location : Columbus, Oh
| Subject: Re: I got a wild idea in my head January 5th 2012, 12:13 pm | |
| If it were me, I'd go with a rear engine setup and possibly a chain drive. Then build a firewall/bulkhead behind the driver's seat. You could weld the engine compartment up to make a trunk of sorts if you wanted. Personally I'd probably mount a winch in there and a fairlead plate where the hood comes down. Maybe a dual battery setup for the winch. Maybe throw on an on board air setup.
Then you could modify the axles to have them stick out further than the body for a low center of gravity build. Something like that with a short wheel base, some descent articulation and the right tires would be a monster.
Incase you can't tell, I'm a Jeeper and think like a Jeeper.
EDIT: I just played with some numbers, and without a transmission. An engine turning at 6,000 (think motorcycle) with 33 inch tires and a 10:1 gear ratio would still give you a top speed of 58MPH. Assuming my math is correct. 20:1 *should* net you 29 MPH and enough torque to clime a wall. An engine turning at 3,000 (think lawn tractor) and a 10:1 with 33's would also be roughly 29 MPH. | |
| | | MSteele323 Member
| Subject: Re: I got a wild idea in my head January 5th 2012, 2:12 pm | |
| - Jamus wrote:
- What's wrong with the stock motor, blown? The geo 3cyl is a popular swap into larger buggies like joyners and roketas. If you haven't found one yet, look for the elusive CVT transmission, or better yet, a subaru just which is basically a 4wd metro. If I could find a complete metro I'd strip it down and make a rear wheel drive 2-seat buggy out of it.
well there is a guy down the street that deals in junk metros. and i thought it would be a neat idea to play around with one of these dull cars. | |
| | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4939 Posts : 208 Location : Tennessee
| Subject: Re: I got a wild idea in my head January 5th 2012, 2:42 pm | |
| I'd almost like a 4 door Metro, I would cut the body from the rear end to just behind the front doors. Think of like a road legal Japanese mini-truck | |
| | | dagr8tim Member
| Subject: Re: I got a wild idea in my head January 5th 2012, 2:44 pm | |
| - AcreFarm wrote:
- I'd almost like a 4 door Metro, I would cut the body from the rear end to just behind the front doors. Think of like a road legal Japanese mini-truck
I saw that done with a Ford Tempo once. There's a guy with a Jeep Cherokee that he did that and he did the fit and finish right. | |
| Who is online? | In total there are 41 users online :: 0 Registered, 0 Hidden and 41 Guests
