 Koopa the Murray.
5 posters
Slipperz
Slipperz
Koopa the Murray.  Empty
PostSubject: Koopa the Murray.    Koopa the Murray.  Icon_minitimeAugust 29th 2024, 12:12 am
So my friend is back with another Murray build! This one a factory MST-205(I think) The OG 14.5 OHV Briggs that came in it he took out (I think it was far to far gone) and put a 12 hp Flatty in its place. This engine is a known good runner from an old DynaMark I helped him get running. (The DynaMark is the tractor the Spicer in his last tractor is from.) He just need to get a new carb for it and engine wise this thing should be good to go!
Koopa the Murray.  Fd10
Koopa the Murray.  Sd10
He is in the process of pulling the trans pulley off, but it is fighting him. He is going to try and run a 1:1 pulley ratio.
The shaft that has been giving him trouble.
Koopa the Murray.  Asd10
The pulley he is going to run is and OG pulley from a hydro Murray. it is a little bit smaller.
Koopa the Murray.  Df10
He is going to use some 22x8x11 tires from a Honda ATC.
He is going to keep working on it and I will be able to document it for you guys here on ATLTF!
Koopa the Murray.  Dfdf10
Koopa the Murray.  Ss10
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeAugust 29th 2024, 12:42 am
Sometimes its better to just cut those dang pulleys off. Has he tried the torch and wax trick? That usually works pretty alright.
Looking forward to seeing the build! :cheers!:
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeAugust 29th 2024, 12:09 pm
Nice! Looking forward to the build!
Koopa the Murray.  Sig115PROJECTS:
Koopa the Murray.  Sig214Koopa the Murray.  Sig314
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeAugust 29th 2024, 7:44 pm
Bowser, now Koopa…
Somebody needs to do an AYP build called “Mario.” Koopa the Murray.  1098998679
Looks like a start of a cool mow-chine
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeAugust 29th 2024, 11:30 pm
Rustbucket Garage wrote:
Bowser, now Koopa…
I know, I got a good chuckle out of it. I love it.
Danceparty
Rustbucket Garage and ranch king pro 08 like this post
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeAugust 30th 2024, 12:03 am
Or a JD named “Luigi….” But I digress
ranch king pro 08
ranch king pro 08
2023 Build-Off Top 3 Winner
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeAugust 30th 2024, 12:37 am
Princess Peach anyone?Koopa the Murray.  36e8f710
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeAugust 30th 2024, 1:07 am
[adm]This poor thread has gone all off track.[/adm]
Koopa the Murray.  Off-to10
Slipperz
Slipperz
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeSeptember 10th 2024, 10:52 am
So my friend finally got the trans pulley off after much struggle.
He cut the old hub out and is going to use a pulley from an old DynaMark. (Last post i said hydro Murray. I was mistaken.) He is using self tappers to hold the new pulley together. He did grind down the screws so they are not just spinning wheel of death. lol
Koopa the Murray.  Hgtgh10
Koopa the Murray.  Ijkjk10
Koopa the Murray.  Asdasd10
He was able to use the OG belt after installing a new idler pulley. He also did a pulley flop on the front pulley and drilled a hole in the crankshaft, so he is going to be using a 1:1 ratio.
Koopa the Murray.  Adsasd10
Next on the list is a carb, tires, and he needs to fix the steering.
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeSeptember 10th 2024, 6:38 pm
HOLY CRAP! I mean, uhhh, well, like I can’t even be mad really, but just wow. I wonder how long it’ll hold together. I would probably have cut the self tappers off a bit over flush and then peened over the rest like a rivet. Then they wouldnt come out.
Slipperz
Slipperz
PostSubject: Re: Koopa the Murray.    Koopa the Murray.  Icon_minitimeSeptember 11th 2024, 10:23 am
@RichieRichOverdrive I think the pic shown is not how it looked when done. I think he cut the self tappers shorter I just didn't get a pic of it. We will see how long/well it holds up. If it fails he can weld it using the self tappers to hold it center. lol
RichieRichOverdrive likes this post
Koopa the Murray.
» the murray
» Murray Monster Mudder
» Murray "Green Machine" Mud Mower
» Murray 11/36
