 Oppy 19.5 and Tecumseh transaxles
Hillbilly mowers
Hillbilly mowers
Oppy 19.5 and Tecumseh transaxles  Empty
PostSubject: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 11:11 am
Well guys I got these in today and I got few questions on them cause the oppy is my 1st ever had in my hands and I hear u all talk about them here . And I'm want the best out of it and the transaxles and here's the pic of both.Oppy 19.5 and Tecumseh transaxles  Img_2130
Oppy 19.5 and Tecumseh transaxles  Img_2128
[img]
Oppy 19.5 and Tecumseh transaxles  Img_2132
[url=https://servimg.com/view/20526907/175
Oppy 19.5 and Tecumseh transaxles  Img_2133
Hillbilly mowers
Hillbilly mowers
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 11:16 am
Oppy 19.5 and Tecumseh transaxles  Img_2134
Oppy 19.5 and Tecumseh transaxles  Img_2136
Oppy 19.5 and Tecumseh transaxles  Img_2135
Here's the rest
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 3:36 pm
Waiting on questions... lol.
Also post more complete pics of the transaxle to help with identification, unfortunately that number is just a casting number of the housing, look for a metal tag or a flat machined area on the casing where the model number would be etched/stamped in. A picture of the model and serial number on the engine would be helpful as well.
Looks like a good haul regardless!
My All Terrain Tractors:
Hillbilly mowers
Hillbilly mowers
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 3:54 pm
@Brianator Oppy 19.5 and Tecumseh transaxles  Img_2137
The transaxle only has the stamps that are in the pic a here some an the gasket bad behind the brakes a thats the questions on it .how can I replace it Oppy 19.5 and Tecumseh transaxles  10000010
Oppy 19.5 and Tecumseh transaxles  10000011
An on there motor in need a starter for but have another but it a 16 hp oppy that has a brand new starter on it an new coils an it run until it git hot then die an u have wait hours for it to start back an the coils wasn't cheap they 50 for two .and will parts from this 16 work on the 19.5Oppy 19.5 and Tecumseh transaxles  Receiv25
Hers the one run till it git hot an shut off and it has two new coils and brand-new starter.
Hillbilly mowers
Hillbilly mowers
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 4:11 pm
@Brianator Oppy 19.5 and Tecumseh transaxles  Img_2138 I went out there and found the tag sticker
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 4:37 pm
Running until hot then shutting down makes me think it could either be low compression or bad coil(s). The parts from the 16hp very well might work, I think they were close to the same vintage but can't know for sure unless you post the ID tags of both engines.
You have yourself a MsT206 which is a 6 speed and a fairly decent trans! Based on the numbers it's a regular duty unit and not an HD bit they're fairly tough regardless! Yours has the short shifter shaft so it's not likely from a Murray which tend to have tall ones, to replace the seal around the brake it must be opened up, I'm not sure of the actual part number for it off hand but maybe someone else does? Can't be too hard to track it down.
Nice score on those!
Hillbilly mowers
Hillbilly mowers
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 4:42 pm
@Brianator man I just got them for 45 a peice
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 4:45 pm
That's awesome!
Hillbilly mowers
Hillbilly mowers
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeDecember 30th 2023, 5:00 pm
@Brianator I'll git them number of the engine after 9 so I can git out there to work some cause other than I got the kiddos and that why I can't git out there during the day
Hillbilly mowers
Hillbilly mowers
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeJanuary 2nd 2024, 5:46 pm
Hey guys dose the MST 206 take the bearing as the spicers doseOppy 19.5 and Tecumseh transaxles  Screen47 these bearing
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeJanuary 2nd 2024, 6:56 pm
That part number does look right but don't be afraid to browse the site and also use the "Search" bar, the amount of information that's on this site is staggering although it can be tough to find at times (which is something I'd like to start working on) but I learned so many little things just by cruising around through the different sections and reading ALOT! Lol.
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeJanuary 2nd 2024, 7:01 pm
Someone at one time wrote those specs down for a 206.  It's what's in the FAQ section on the page.
Oppy 19.5 and Tecumseh transaxles  Sig115PROJECTS:
Oppy 19.5 and Tecumseh transaxles  Sig214Oppy 19.5 and Tecumseh transaxles  Sig314
Hillbilly mowers
Hillbilly mowers
PostSubject: Re: Oppy 19.5 and Tecumseh transaxles    Oppy 19.5 and Tecumseh transaxles  Icon_minitimeJanuary 2nd 2024, 8:09 pm
@MightyRaze @Brianator I found this in the FAQ I nailed it MST Series (202,203,204,205,206)
MST Series Axle Bearing - 6203-12-2RS, 6203-2RS-3/4, 19.05x40x12mm
» peerless tecumseh transaxles manual
» B@S oppy help
» 18hp oppy?
» 42 c.i. oppy carb
» B&S 18 HP Oppy Questions
All-Terrain Lawn Tractor Forum :: New Member Forum :: New Member Help and Site Tips-
