 Spicer 2000
Hillbilly mowers
Hillbilly mowers
Spicer 2000  Empty
PostSubject: Spicer 2000    Spicer 2000  Icon_minitimeDecember 20th 2023, 9:55 am
Alright guys I'm having trouble with a Spicer 2000 that I got for 10 bucks and it shifts good and no problem there but my problem is in the casein right by the shifter shaft on the top casing has a hole where someone tuke a cutting grinder to it for some reason I do not know why they would do that Spicer 2000  Img_2124
Spicer 2000  Img_2122
Spicer 2000  Img_2123
I'm wondering how I could fix it . 1 jb weld or 2 soldering to gethere I just trying to fix it cause I got it for 10 buck
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 20th 2023, 9:57 am
I'd Jb Weld it, it's quick and easy and strong.
My All Terrain Tractors:
CRAFTSMAN MUDDER likes this post
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 20th 2023, 9:58 am
I'd say, clean it up good and JBWeld.  What is is going to hurt at this point.
Spicer 2000  Sig115PROJECTS:
Spicer 2000  Sig214Spicer 2000  Sig314
Hillbilly mowers
Hillbilly mowers
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 3:21 pm
This is a update ont the Spicer 2000 for now wel I got it aparts and il clean out the grease and stuff and all the gears are in going shape and I was want to put bearing back in it to help support the axle shafts but I don't know the size it would take cause I don't have a mmtool to size the gap with for the bearing and I was wondering if someone on here know the exact size of bearings I would need an have I can convert it to oils instead of greaseSpicer 2000  Receiv22
Spicer 2000  Receiv24
Spicer 2000  Receiv23
That before an an I'll have to the after cleaning pictures
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 4:05 pm
Post a pic like the first one but strait up and down and showing from where the bullgear sits all the way to the end of the case (just need to see one half of it) and I'll see if I can figure it out for you by resizing the photo and using my caliper.
Hillbilly mowers
Hillbilly mowers
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 4:23 pm
@Brianator will these help out man Spicer 2000  Img_2126
Spicer 2000  Img_2125
Cause i could leave the kids long by there self to git more pic
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 4:41 pm
Assuming that's a 3/4" axle you need 1630-2RS bearings which are 1-5/8" OD, 3/4" bore and 1/2" thick. Silicone the bodies in the housing, leave the rubber caps on and fill the case around the axles with grease between the bearings and the outer seals to slow down oil from escaping.
Hillbilly mowers
Hillbilly mowers
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 5:22 pm
@Brianator thanks man an the other name on the transaxle is a Dana Spicer 2000 and and that was my plan on silicon or some permatex that should in some 90 weight gear oil because I think grease is bad on the gear I want to git the best out of it by modify it Alil so I can use it my build off tractor the 1st of January but IV had few set back. But after the 1st of the years thang are looking better an I have my entry form read.
Hillbilly mowers
Hillbilly mowers
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 6:03 pm
@Brianator  is these the one I needSpicer 2000  Screen45
Rustbucket Garage
Rustbucket Garage
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 6:31 pm
Them oughta do it. I guess some people like the seals and some don’t so that’s up to you. Can use a pick and pull em out if ya don’t.
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 6:32 pm
Ya man, if you can afford good quality ones it would be a good choice for durability, it's going to be alot of work to replace them if cheap ones don't hold up long.
I recommend leaving the seals in, oil WILL seep in and through them. I noticed your case has a seal at the end of the channel for the axle but it's not new and you'll want all the help you can get to the hold oil in.
Hillbilly mowers
Hillbilly mowers
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 6:50 pm
@Brianator @Rustbucket Garage  thanks guys I'm going to keep the rubber seal but I'm think about replacing them with new one if I can find them or would grommets work as well as them seal no and I want it to hold for years to come so I want the best in it .
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 6:59 pm
We're actaully talking about the rubber seals that are on the bearings themselves, they're removable. Spicer 2000  20231240
If you can find new outer seals that's an excellent choice! Look for more numbers on the case like an info tag hopefully. It's a 2000 but a 2000-???? Could make all the difference in finding the right ones
Hillbilly mowers
Hillbilly mowers
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 7:04 pm
@Brianator no man I'm not removing the seal I am replacing the outer rubber seal for extra protection and the outer seal was the one I thought un was talking about but no man I want all the help I can git to hold my oil in so it will last a very long time un till I can afford another or can find a 820 or something in that nature
Hillbilly mowers
Hillbilly mowers
Spicer 2000  Empty
PostSubject: Re: Spicer 2000    Spicer 2000  Icon_minitimeDecember 23rd 2023, 7:08 pm
And @Brianator to add to it will be out there in my lil shop work when my woman gits home from work so I can work some out there and I will look more as I clean it up and git all that nasty grease out of it an clean down the out casein so I can see more numbers an stuff but it a 5 speed with reverse I counted the notches as I shifted it
Spicer 2000  Empty
Spicer 2000
» My 2000 Craftsman build.
» Fordification's LGT-2000 build.
» The Murrat 2000 Knight rider style
» Hey got a project ive been working on its a late 90's early 2000 mtd
» Peerless 930 4spd Good or Bad
All-Terrain Lawn Tractor Forum :: New Member Forum :: New Member Help and Site Tips-
