| Using Pto shaft gerbox (90°) on lawntractor engine | |
MoTiJo Member
Age : 17 Join date : 2023-01-02 Points : 787 Posts : 73 Location : Germany
| Subject: Using Pto shaft gerbox (90°) on lawntractor engine November 2nd 2023, 5:44 pm | |
| Hello, I have a question for you guys. Has anyone of you ever tryed to use a PTO shaft gearbox that you find on big and small agricultural tractors and connect it to a lawntractor egnine (i have a 11hp one) so you have a horizontal shaft for a gokart axle? I looked on google and there are also smaller pto shaft sizes, so this should work without robbing the engine much power, right? | |
| | | MoTiJo Member
| Subject: Re: Using Pto shaft gerbox (90°) on lawntractor engine January 28th 2024, 4:14 am | |
| Because no one has replied, Im just gonna order one of those gearboxes and try to use them on a horizontal shaft honda engine and connect the engine with this 90° gearbox to a stock Lawntractor transaxle. A gearbox (the one on the picture in my post above) is 80€ and im ok with that price so im gonna try it. | |
| | | Brianator Moderator
| Subject: Re: Using Pto shaft gerbox (90°) on lawntractor engine January 28th 2024, 10:31 am | |
| Sorry man I don't remember seeing your question or I would've replied, I've never used one like you're wanting to but can offer a little insight. Yes it's going to rob a little bit of power (probably 1-2 hp) there's no getting around that but only the manufacturer will truly have an idea of how much. The gear ratio is going to make a big difference as well, do you know what it is? If I were you I'd be researching into the gear ratios of a Peerless 700 gearbox and their uses in mower racing to get an idea if this gearbox could work as you want it to.
Hope this helps a little. | |
| Subject: Re: Using Pto shaft gerbox (90°) on lawntractor engine January 28th 2024, 12:52 pm | |
| Aye... guess the notification thing goes back further than I thought. I agree with @Brianator! HP loss would be minimal. CarsandCamera's used one with a 5hp engine for a red wagon go-kart and they had no issues with the right angle gearbox. | |
| | | MoTiJo Member
| Subject: Re: Using Pto shaft gerbox (90°) on lawntractor engine January 31st 2024, 10:21 am | |
| @Brianator The Gearbox has a gear ratio of 1:1, so there is no change in the output shafts speed. The reason why i want to use the 90° gearbox is because i want to have a chinese honda GX clone (200cc) to drive a peerless 700 gearbox for one of my projects, i cant get a real lawntractor transaxle for cheap here in germany. I dont know the gear ratios of the peerless 700's i have laying around.... | |
| | | muddybasilisk Member
Age : 15 Join date : 2024-01-08 Points : 396 Posts : 57 Location : North Texas/DFW
| | | | MoTiJo Member
| | | | JB_4x4 Member
Age : 63 Join date : 2023-04-25 Points : 877 Posts : 257 Location : Atlanta GA
| Subject: Re: Using Pto shaft gerbox (90°) on lawntractor engine February 22nd 2024, 4:52 am | |
| FWIW: Those RAGB for AGRI usually have an 1800 RPM speed limit. You can buy them at surpluscenter, ECC, etc. So, I would think about having a 2:1 ratio on the pulley system if not being direct drive with a lovejoy connector. | |
| Who is online? | In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests
