 1980 MTD 918 - 'Ol Rusty!
PizzaKitty26
Silver_Pharaoh
10 posters
Silver_Pharaoh
1980 MTD 918 - 'Ol Rusty! - Page 6 Empty
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 24th 2023, 12:36 pm
Brianator wrote:
No worries, I couldn't have stayed long anyhow. I'll let you know next time I'll be down that way.
Works for me man!
If things work out maybe I'll be able to bring the tractor out your way and we can go for a ride 1980 MTD 918 - 'Ol Rusty! - Page 6 1f603
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 24th 2023, 12:50 pm
Sounds good to me! There are LOTS of trails just down the road from me!
My All Terrain Tractors:
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 29th 2023, 4:08 pm
Hoo boy! She's ghetto but it drives under it's own power! 1980 MTD 918 - 'Ol Rusty! - Page 6 1f60e
She bucks in 4th gear, boy that's scary without brakes lol.
Definitely not riding again until I get the brakes together.
1980 MTD 918 - 'Ol Rusty! - Page 6 2023-130
1980 MTD 918 - 'Ol Rusty! - Page 6 2023-128
1980 MTD 918 - 'Ol Rusty! - Page 6 2023-129
Lots of play when the clutch is engaged, definitely need to tweak it more. Right now I can't shift gears unless the motor is off. I suspect that's because the brake isn't working yet, so the transaxle is always spinning a bit as the lose belt catches the pulley. Once the brake works (need to find a spring and adjust it) I think I'll be able to switch gears with the motor running.
Any thoughts or tweaks you guys see that can be made?
I'm thinking stronger spring on the clutch or some different setup maybe spaced out more?
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 29th 2023, 4:32 pm
Brakes won't help you with shifting, belt guides around the pulleys are what provides braking to the belt such as this, without them the belt won't fully come off the pulleys. There's a possibility you'll need more slack or a longer belt. The 2300 did come with a plate that had little belt guide tabs on it but you'll need some in the motor as well. 1980 MTD 918 - 'Ol Rusty! - Page 6 20230981
I'd say your clutch pulley is upside down, you want the tab up and that flat idler to be pushing down on the belt, correct me if I'm wrong but this rod (circled) looks like it would connect between the pedal and the clutch so it would pull the flat idler up to disengage the clutch.1980 MTD 918 - 'Ol Rusty! - Page 6 2023-110
You're getting close! Glad it's moving under power now!
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 29th 2023, 4:55 pm
Here's a pic of what the trans mounting plate with belt guides looks like. Those little tabs prevent the belt from coming too far out of the pulley which is turn allows it to slip when the clutch is pushed in. That plate bolts to the trans behind the pulley and based on your pics maybe you didn't get it with the machine or trans? It's a big triangular plate. 1980 MTD 918 - 'Ol Rusty! - Page 6 20230596
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 29th 2023, 5:10 pm
That rod you circled connects to the "speed control lever" I disconnected it for now to use the hole to attach the clutch.
So if I understand correctly, those tabs and guide kinda flex the belt in such a way that it stays off the pulleys right?
And I am definitely missing that triangular piece you showed. I'll have to make something up
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 29th 2023, 5:15 pm
I think that circled rod could be replaced or lengthened to give the clutch the proper action, it's kind of upside down and pulling on the belt for tension instead of pushing.
Yes that's essentially what they do, they allow the belt to come off the pulley for slip without it coming all the way off the pulley. They also prevent it from stretching way out and grabbing the pulley and provide a braking effect for the belt itself.
You're so close man, I'd really love to get down there soon and guide you along
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 29th 2023, 6:27 pm
Sounds good man! Now that it runs and drives, I'm going to tackle the smaller things on it and do the bigger tasks towards springtime. I know my father in law is itching to work on his Pontiac Lemans so he'll be needing the garage for a while.
I'll find some 1/4" rod or something and bend up a few belt guides. Two around the motor, two around the trans pulley probably.
Need to figure out the front wheels, either leave them as is and remove the slop, or find a way to put bearings on them so they don't wear down the shafts they sit on.
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 29th 2023, 7:03 pm
Alot of front wheels have a 1-3/8" bore and you can replace the bushings with bearings that are easy to get on Amazon, you won't find the right ones at Princess Auto.
https://a.co/d/4eqrsQo
Those are just cheap ones but better quality ones are available.
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 29th 2023, 10:50 pm
On the subject of wheel bushings... my MTD had white plastic wheel bushings up front. It appears they had never been lubricated. Those bushings had worn notches clear into the spindles! The really crazy part was that the plastic was still super tight coming off the parts of the spindle that weren't worn- the bushings hadn't worn a bit in 40 something years! I just went ahead and greased them and ran them. I'm not even sure if they were the normal 1-3/8 size bushings.
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 30th 2023, 8:39 am
Yeah that would have worked, but I put snow blower tires on for the tread they had and I liked the narrow profile 1980 MTD 918 - 'Ol Rusty! - Page 6 1f605
I'll have to nab some fronts later on probably then.
Holy cow what kind of plastic is that?? I'm worried about wearing down my spindles as well, but I've already greased them well once so hopefully wear will be low for the time being.
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 30th 2023, 3:41 pm
Good point @RichieRichOverdrive, I have a couple pairs of 6" MTD front wheels that came with plastic bushings and I believe the bore on them was 13/16", basically impossible to find actual bearings for them (needle roller being the only option and expensive).
@Silver_Pharaoh I've wondered that as well and my best guess is that it's what's known as "bakelite", before modern plastic that's what alot of plastic things were made with and it was really durable.
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 30th 2023, 5:52 pm
They were definitely not bakelite, bakelite is fiber material in resin, usually canvas or cotton in resin but glass fiber and paper can also be found. Not suitable for thin walls like bushings have. These bushings were not fibrous but a solid white plastic. Too hard for UHMW i think, likely nylon or delrin.
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeDecember 31st 2023, 9:58 am
Thanks for the history lesson @RichieRichOverdrive!
RichieRichOverdrive likes this post
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 8th 2024, 11:31 am
Back on afternoons for now, so I have time to tinker! Also gave her a name- Ol'Rusty! Seems kinda cliche maybe but I think it fits. I mean, it is Rusty and I like that 1980 MTD 918 - 'Ol Rusty! - Page 6 1f606
Installed the control lever I got from Amazon since this motor was from a genny it did not have one.
1980 MTD 918 - 'Ol Rusty! - Page 6 2024-011
1980 MTD 918 - 'Ol Rusty! - Page 6 2024-012
1980 MTD 918 - 'Ol Rusty! - Page 6 2024-010
Also mocked up some belt guides, initial testing looks good with the wheels in the air, I'm able to shift with minimal grinding. Once I get the motor belt guides figured out I think that will work well.
1980 MTD 918 - 'Ol Rusty! - Page 6 2024-016
1980 MTD 918 - 'Ol Rusty! - Page 6 2024-018
1980 MTD 918 - 'Ol Rusty! - Page 6 2024-017
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 8th 2024, 8:23 pm
@Silver_Pharaoh that U bolt as an adjustable belt guide is a great idea
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 9th 2024, 9:51 pm
Thanks! I figured they would come in handy, and they were a good long length too so I figured that couldn't hurt.
Took it for a spin today and it was pretty fun! Need to secure the battery and fix a loose kill wire, but it drives and has some brakes lol!
Last edited by Brianator on January 9th 2024, 11:00 pm; edited 1 time in total (Reason for editing : Fixed YouTube link.)
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 9th 2024, 11:03 pm
It lives! That's awesome @Silver_Pharaoh, sounds like that motor is running great, I also like the Ubolt belt guides... thats pretty slick!
To embed a YouTube video you'll notice a YouTube button in the top bar of the messge box, all you have to do is copy the link address there and hit "insert". I fixed the above one for you, the first one's a freebie! Lol
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 9th 2024, 11:15 pm
Thanks! How much will it cost next time? 1980 MTD 918 - 'Ol Rusty! - Page 6 1f602
PizzaKitty26
PizzaKitty26
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 10th 2024, 8:35 am
I will be using that!
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 10th 2024, 12:29 pm
1980 MTD 918 - 'Ol Rusty! - Page 6 20200512
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 11th 2024, 2:06 pm
Every once in a while I think of something. Every blue moon I think of something good 1980 MTD 918 - 'Ol Rusty! - Page 6 1f602
Got ya covered 1980 MTD 918 - 'Ol Rusty! - Page 6 1f60e
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 20th 2024, 12:56 pm
Been using Ol'Rusty to pull stuff around the yard, and my father in law is loving it so much he bought his own tractor:1980 MTD 918 - 'Ol Rusty! - Page 6 2024-019
Same transaxle, a Peerless 2300, opposed twin 16hp Briggs and already has ATV tires all round!
Previous owner welded on Suzuki hubs for the front too! Even comes with a snowblower!
Definitely curious to see how this vertical shaft drives the 2300. I'll take a peak at it later!
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 20th 2024, 1:18 pm
That Dynamark GT looks to be in GREAT shape.
If I were guessing, the belt twist probably looks like a Murray of similar generation.
1980 MTD 918 - 'Ol Rusty! - Page 6 Murray10
1980 MTD 918 - 'Ol Rusty! - Page 6 Sig115PROJECTS:
1980 MTD 918 - 'Ol Rusty! - Page 6 Sig2141980 MTD 918 - 'Ol Rusty! - Page 6 Sig314
Silver_Pharaoh
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 20th 2024, 1:25 pm
Ahhh that's how they did it! I kept wondering how they did it and kept the belt on. Thanks!! 1980 MTD 918 - 'Ol Rusty! - Page 6 1f603
PostSubject: Re: 1980 MTD 918 - 'Ol Rusty!   1980 MTD 918 - 'Ol Rusty! - Page 6 Icon_minitimeJanuary 21st 2024, 4:02 pm
I always thought that series of Dynamark had an awesome paint job. I wonder if any of them had right angle gearboxes instead of a belt twist.
Page 6 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» Ole Rusty Red **(UPDATED)**
» Rusty Metel #2
» Rusty red (wheel horse C105)
» RED STAG 69 Raider 12 The Best Rusty Copy
» 1980 Roper 16T
