 [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower
TechnoChicken
muddstir
8 posters
[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Empty
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJanuary 23rd 2023, 10:19 pm
Okay, so I have good news and "other news". Lol
First the good news!
The (weld on) pulleys and engine hub came today! I settled on 6.5" front and 4.5" rear which works out almost the same a 6"/4" but with more belt gription and a slightly lower ratio for more speed![23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230185
In "other news":
With the front pulley sitting flush at the end of the PTO there's quite the void to fill but I need the pulley there for alignment... I'm thinking that if I get a new front pulley for The WarHorse, cut it's stock pulley tube to length then weld it onto the engine hub so it's full length then I can bolt it down as well as use the keyway and set screws so no biggie right? I think that's a decent plan anyways! This should also allow me to extend the pulley past the end of the PTO if I need to.  [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230186
While we're talking about pulley alignment check out how the rear pulley sits about 1" lower than the front when it's sitting directly at the base of the input shaft, theoretically where it could with a hub...[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230187
...which brings me to my next points:
~With the tops of the rear tires already almost touching the fender pan (which is at stock height) I can't raise the trans in the chassis much more to get the pulleys to align... a little perhaps but not alot.
~The 5/8" hub for the rear pulley will work great for the MST that's destined to go in but it won't for the FNRs 1/2" input shaft and I'd like to run the FNR at the start.
So here we have a dilemma within a dilemma, even if I got a 1/2" pulley hub it still couldn't get the pulley where it needs to be nor would it on the MST... but with the pulley sitting as close to the case as it can alignment looks decent.[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230188
Luckily I'm pretty creative and have a bunch of parts kicking around!
First I measured the case around the input shaft, 1-3/16" at its largest.[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230189
Okay so maybe I could use a 1-1/4" pulley hub to lower the pulley? But then how to attach that to the input shaft? Well wouldn't you know, both the stock FNRs and MSTs input hubs outer diameter is... you guessed it - 1-1/4"!! I know it's possible to remove the hubs without destroying them or the pulleys because what you're looking at is 2 FNR pulleys, one stock and the other with the MST hub welded in![23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230190
It looks to me like all I'll have to do is bolt the input hub on the trans, install the pulley with a 1-1/4" hub on it, add threadlocker and tighten the set screws... I could even weld the hubs together if I want. I should be able to adjust the trans' height in the chassis to fine tune it as well so I'm hoping this is a big win!
So I guess the "other news" is also good news just more work!  Lol
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJanuary 25th 2023, 7:43 pm
Not really picture worthy but I did get the 1-1/4" hub for the trans today, after cutting the FNR pulley hub out and cleaning it up a bit it fits good and snug inside the 1-1/4" hub! The pulley alignment is close and I'm sure I'll be able to dial it in with trans height and the front pulley as well so I'm feeling really good about it!
What is picture worthy is the hood locking pins that came in today, nice and sleek and aerodynamic plus they'll fit in with the 3/16" fat head rivets that will end up throughout this beast! [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230191
I'm really hyped about this build if you can't tell! Lol
My All Terrain Tractors:
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJanuary 29th 2023, 1:48 pm
More for fun I'll admit but I mounted some old as dirt (but in decent shape!) Goodyear ribbed tires on wheels for the rear which will match the front! I think these will be my pavement tires for grip/speed and for grass/dirt drifting as well![23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230193
I'm not 100% what I'll be up to with this today but I'm motivated to do at least something! Lol
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJanuary 29th 2023, 8:55 pm
I did a little tinkering and made some progress!
I massaged the flares on the fender pan just enough to tuck the rear wheels in and discovered I had way more space from the tire to the fender pan than I thought, about 2" which is super![23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230195[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230194
So I slotted the trans mounting holes and moved the brackets up about an inch which still leaves about an inch from the tires to the fender pan and boy I think it looks good with the tires tucked up in there! More fender flare massaging will happen in the future to shape them but for now it's good.[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230197[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230196
As for pulley alignment that's all looking great, notice that the rear pulley sitting exactly the same on the trans as last time actually sits below the engine pulley now and there's still room for the belt to clear the footboard support rod so it won't be hard to dial it in at all! [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230198[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230199
I wanted to see it mocked up and on it's wheels again so here it is sitting about 4" from the frame to the ground and the top of the hood is 24" off the ground. If you look for it, you'll notice it's sitting back to back with The Warhorse which is the EXACT same make and model of tractor... check out the differences in the fender pan and seat heights! I need get them out and sitting side by side one day for fun! [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 20230100
So now I have a true roller! I should get working on the steering soon so I have a steerable roller, I have a feeling that it's going to take me quite a while to get it done and I don't feel like rushing it! There looks to be more than enough space above the engine pulley to work with, everything just seems to be working out really well so far!
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeMarch 1st 2023, 9:25 pm
Guess it's time for a little update although there's not much to update at the moment...
It's been a busy few weekends so I haven't had a good chance to do anything with it and this coming weekend is also no exception but I am hoping on moving forward soon.
I have all the pulleys and hubs I need but am still waiting on the last set of heim joints I need for the steering, funny how the first 2 sets showed up within a couple of weeks but the third took 3 weeks just to ship...
Regardless, I'm happy with what I've accomplished so far and look forward to getting back to work on it soon!
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeApril 30th 2023, 9:43 am
Man, I've been so busy trying to get stuff done since the weather has improved I haven't gotten anything done on this machine... I really need to get my arse in gear before it's too late there's still lots to do!
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJune 19th 2023, 9:54 pm
Well guys, it's with a heavy heart I say this but after much thought I've decided that I have no choice but to pull out of the build off... I had some big things come up since I last worked on it and still have far too many things that need to be done to pay this build the proper attention it deserves and I don't want to just hack it together. I'll clean the rust off the front axle and everywhere I welded then paint those areas to protect it but that's about it for now, I also have to take the F/N/R out of it and build it for The Warhorse so I can get that going again then move the 3 speed into this.
I do want to build this and I'm excited for it but to give you an idea why I can't right now here's a list of things I need to accomplish before winter:
- build a new exhaust for my car (happening soon)
- lots of bodywork on my car (before it's too late)
- reshingle my workshed
- Install the woodstove in my workshed
- retarp the lean-to on the side of my workshed
- seal the bottom edges of my tractor shed to keep snow out
-  finish the mini shed and seal the bottom to keep snow out
- build a grading blade with ripping teeth for my driveway out of a useless (to me) snowblade that I can use behind the Roper 16T (can be seen HERE) plus a new weight box to use with the 3 point hitch.
- fix the gutters and a few other small things on the exterior of my house
- plus more... there's always more!
This was not an easy decision and I've been working very hard to get things done (doing well at it too!) but there's just not enough hours in the day and work keeps getting in the way! Lol.
Sorry to let down those who were following but rest assured the build is not over, just stalled probably until winter.
Thanks to all who were following along and encouraging me!
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJune 19th 2023, 10:17 pm
Sorry to hear that.  It looked like it was going to be a fun build, but like you said, "I do want to build this".  So, it will be cool to see it out on a later date.
Man, I hear about needing to do the chores.  I have a laundry list of them myself.
[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Sig115PROJECTS:
[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Sig214[23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Sig314
ranch king pro 08
ranch king pro 08
2023 Build-Off Top 3 Winner
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJune 22nd 2023, 9:10 pm
Well man I hate to hear that. But the silver bullet will rise again and be better than ever
CRAFTSMAN MUDDER
CRAFTSMAN MUDDER
1st Place Build-Off 2023
1st Place Build-Off Winner 2023
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJuly 11th 2023, 10:45 pm
Sorry to hear, life stuff always sucks, but good things can't be rushed. The silver bullet will be a real beast once she's done!
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJuly 11th 2023, 11:11 pm
Thanks guys I appreciate it! I do get bummed out everytime I look at it to be honest...
Krawler86
Krawler86
PostSubject: Re: [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower   [23] Brianator's "Silver Bullet" ~ Super Stock Race Mower - Page 3 Icon_minitimeJuly 27th 2023, 11:44 pm
Bummer, i really like the look and ideas you have going on. The height and fit of the wheels and tires inside the rear body tin looks so rad.  If i was building something fast for handling, it would be very similar to what you have going on.  Hopefully it gets built later on in life and a cool tractor can join the ranks of the living.
[mod]This topic is now locked![/mod]
Please follow along here to see the next phase of the journey!
Brianator's "Silver Bullet" Super Stock Race Mower (Take 2)
» [DNF] [24] Brianator's "Silver Bullet" Super Stock Race Mower (Take 2)
» Silver bullet is ready for big may 24 race!
» 53mph on the silver bullet rally mower!
» Silver bullet on the dirt oval.
» race mower
