 Peerless MST 200 series Info and Resources Thread
Peerless MST 200 series Info and Resources Thread Empty
PostSubject: Peerless MST 200 series Info and Resources Thread   Peerless MST 200 series Info and Resources Thread Icon_minitimeNovember 6th 2022, 8:49 pm
So I thought it would be a good idea to start a resource thread for just the Peerless MST 200 series transaxles to help make future searches and referencing easier for all. Anyone is welcome to add their input and experiences, if you find helpful links please post them and I'll copy them into the list. As more info and diagrams are found or submitted it will be added.
The idea came to me because @Krawler86 started this build thread and asked about his MST, both @MurrayMountain and I chimed in and I realized there wasn't a central source of info for them so here we go, let's build it!
Links to MST threads
Bearings for MST transaxles www.atltf.com/t6677-bearings-for-mst-transaxle
MST 206 axles seals www.atltf.com/t6670-peerless-mst-206-axle-seals
MST 205 vs. 930-011 www.atltf.com/t6248-mst-205-and-930-011-questions
Peerless 206 Fluid www.atltf.com/t6061-peerless-206-fluid
How strong is a MST 206?  www.atltf.com/t4742-mst-206-how-strong
MST 200 ball bearings www.atltf.com/t3586-mst-200-series-ball-bering-support
MST 200 Series Info, Tips and Tricks
- They come with up to 6 speeds. The least amount I know of is a 3 speed.
- They have a gear driven reverse instead of chain.
- According to the manual all MST 200s are filled with 16oz of 80w90 gear oil.
- As far as I know all MST cases are the same, @RCG bought a MST203 and put MST206 internals in it. The video can be seen HERE.
- The MST series transaxle by Peerless gear provides recesses for bearings, but doesn't include them. To strengthen your transaxle, order two bearings and install.
- MSTs that come in Murray tractors tend to have a longer shift shaft.
- If you're going to be overspeeding your MST (or any trans for that matter) with a pulley swap and or a high revving engine it's in your best interest to drill, tap and add a vent on a high point on the case where it won't interfere with any internal parts. Pressure that it wasn't intended to handle WILL build up causing leaks, potentially blowing seals and
the worst case scenario would be a cracked case! Yes, it COULD happen. Adding a grease fitting between the needle roller bearings on the input shaft and greasing them regularly will prolong the life of those expensive little bearings you'd rather not replace!
Common MST Parts
- Outer axle seals ------------------------------- Peerless #788088A
- Input shaft seal -----‐-------------------------- Peerless #788083
- Brake shaft seal --------------------‐---------- Peerless #788089A
- Outer shift shaft seal (square cut) ------ Peerless #788069
- Inner shift shaft seal (O ring) ------------- Peerless #788092
- Axle bearings are 6203-12-2RS (2RS stands for the rubber seals which should be removed to allow oil to circulate properly).
.75"xOD40 x W 12mm - MR
Tractors that come with MST 200 series
1991-97 Husqvarna 970-12 ------------------------------MST205-?????? (5 Speed)
1996/97 Agco 514G (Simplicity built) -----------------MST205-5158B (5 Speed)
2001 Murray Widebody LT 40508X92D ------------- MST205-527D (5 Speed)
1999 Craftsman 917.27043 (AYP built) -------------- MST205-544C (5 Speed)
1999-2000 Craftsman 917.27077 (AYP built) ------ MST206-545C (6 Speed)
2001 Craftsman LT1000 917.27205 (AYP built) --- MST206-545C (6 Speed)
1998 Murray Widebody 42505X92A ------------------ MST206-502C (6 Speed)
Keep in mind this is just a start but I'll slowly add to it and hope some of you will help!
My All Terrain Tractors:
PostSubject: Re: Peerless MST 200 series Info and Resources Thread   Peerless MST 200 series Info and Resources Thread Icon_minitimeNovember 6th 2022, 8:55 pm
Diagrams and Info
Quick Reference SheetPeerless MST 200 series Info and Resources Thread Scree133
The 6 pages from the Peerless ManualPeerless MST 200 series Info and Resources Thread Scree134Peerless MST 200 series Info and Resources Thread Scree136Peerless MST 200 series Info and Resources Thread Scree135Peerless MST 200 series Info and Resources Thread Scree139Peerless MST 200 series Info and Resources Thread Scree138Peerless MST 200 series Info and Resources Thread Scree137
MST206-545C Parts breakdown and numbersPeerless MST 200 series Info and Resources Thread Scree209Peerless MST 200 series Info and Resources Thread Scree210
PostSubject: Re: Peerless MST 200 series Info and Resources Thread   Peerless MST 200 series Info and Resources Thread Icon_minitimeNovember 6th 2022, 10:16 pm
More tractors for your list:
My 98 Murray Widebody 42505X92A came with the MST206-502C  (6-Speed)
My '01 Murray Widebody LT 40508X92D came with an MST205-527D (5-Speed)
Peerless MST 200 series Info and Resources Thread Sig115PROJECTS:
Peerless MST 200 series Info and Resources Thread Sig214Peerless MST 200 series Info and Resources Thread Sig314
PostSubject: Re: Peerless MST 200 series Info and Resources Thread   Peerless MST 200 series Info and Resources Thread Icon_minitimeNovember 7th 2022, 8:58 pm
*Added to list* Thanks @MightyRaze!
PostSubject: Re: Peerless MST 200 series Info and Resources Thread   Peerless MST 200 series Info and Resources Thread Icon_minitimeNovember 7th 2022, 11:19 pm
Peerless Manual
Tecumseh / Peerless Motion Drive System (wfmfiles.com)
Also, that oil seal part is the same for MST 205 and 206
788088, I believe the 788088A is the replacement part number for both.
PostSubject: Re: Peerless MST 200 series Info and Resources Thread   Peerless MST 200 series Info and Resources Thread Icon_minitimeJanuary 3rd 2024, 9:17 pm
I'm bumping this thread because I've added some info (parts numbers for common parts) and a diagram/parts number list and so people know this thread exists. I've also stickied it at the top of the section so it's easier to find.
MightyRaze and Hillbilly mowers like this post
Hillbilly mowers
Hillbilly mowers
PostSubject: Re: Peerless MST 200 series Info and Resources Thread   Peerless MST 200 series Info and Resources Thread Icon_minitimeJanuary 3rd 2024, 9:23 pm
@Brianator thanks man this is very helpful to me cause I want my MST 206 to last for many of years until I can find one better
» peerless 600 series
» Peerless 801 info.
» Peerless 820 info wanted
» Peerless 1200 info?
» Peerless 820 how-to info needed
