 Wifey Deere
fbisurveilancevan
6 posters
Go to page : Previous  1, 2
Wifey Deere - Page 2 Empty
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 9th 2022, 4:52 pm
Two more and I’m done for now, hope you like em 😬
Wifey Deere - Page 2 5083c510
Wifey Deere - Page 2 493a0a10
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 9th 2022, 8:00 pm
It's looking killer! Keep up the good work!
My All Terrain Tractors:
diddie
diddie
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 9th 2022, 8:58 pm
Heck ya! lookin good !! keep the updates coming !
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 12th 2022, 12:39 pm
Thanks guys, I went down to dads and did some machining I been putting off for a bit, since the front axle is wider I needed a wider tie rod and I had these trx90 tie rods and ends kicking around so I decided to use them that way I have a tight and a left so I can adjust the rod without unbolting it cut the tierod down to a 2 inch stub then drilled out the rod so they barely slip in.  Decided to get fancy and add some wrench flats to make adjusting it easier
Cutting the flats
Wifey Deere - Page 2 2e58ca10
Checking fitment of a 5/8 wrench
Wifey Deere - Page 2 C4397010
After a little deburr session
Wifey Deere - Page 2 6b21bd10
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 12th 2022, 12:44 pm
Overall view before the flats
Wifey Deere - Page 2 Fdbae610
Close up, ended up pulling them back out and drilling for plug welds also just for some extra security
Wifey Deere - Page 2 9891b510
Last but not least, made some 1 inch to 3/4 adapters for the front spindles, so I can run 1 inch wheels on my 3/4 axle. Still need to make the stops and big heavy washer to bolt the wheels on but I didnt find any 1.5 stock at dads and I had some at my house but it was too late to go back and grab it
Wifey Deere - Page 2 E86e4c10
MightyRaze, diddie and Brianator like this post
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 12th 2022, 2:52 pm
Such a pro job.  Very nice fabrication.
Wifey Deere - Page 2 Sig115PROJECTS:
Wifey Deere - Page 2 Sig214Wifey Deere - Page 2 Sig314
diddie and TechnoChicken like this post
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 12th 2022, 9:45 pm
Thanks Mighty!
diddie
diddie
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 12th 2022, 10:28 pm
wish i had access to some machining tools i could do some great things ! and maybe a plasma cutter and cnc whooo doggies the things i could do !! and the metal i could waste lol.
MightyRaze and TechnoChicken like this post
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 9:47 am
Been hard at in the garage big update for here I’ll try to get up as I get time today. Diddie yes having good tools makes a world of difference, I’ve been using my grandpas lathe and mill most my life but actually bought my own last year, just working on getting the building for them done so I can set em up. It’s been a life goal for awhile to own my own and I only have about 2200$ in the pair. I know people who spend that at the bar in a years time easy. Next tool I’m planing on buying is a concrete plasma setup like what grind hard uses but that will take me a couple years of saving to do.
Been working on getting full steering out of this, this was the first round which went good till I realized the Ackerman angles was wrong 😑
Wifey Deere - Page 2 B2560b10
Wifey Deere - Page 2 6cc3bc10
Wifey Deere - Page 2 588d3310
Last edited by Creepycrawler on September 21st 2022, 10:07 am; edited 1 time in total
diddie likes this post
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 9:50 am
So back to the drawing board, used this aluminum square tube to help line up for proper Ackerman
Wifey Deere - Page 2 7a801710
Then used CAD (cardboard aided design 🤪) to help mock up the shape of the new arms
Wifey Deere - Page 2 97024610
Then made em in metal
Wifey Deere - Page 2 C5be2c10
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 9:56 am
Onto the brakes! The gokart band brake setup didn’t transfer over to the 820 well, mounting holes didn’t line up, (doh!)
Wifey Deere - Page 2 53805a10
But I made these brackets bolt on the back side so it all worked out
Wifey Deere - Page 2 E1482b10
The last time the brake linkage wasn’t adjustable which was a pain so I decided this go around the would be, so built this offset thing which will make sense here soon
Wifey Deere - Page 2 51b0a710
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 9:59 am
Test fit looks good
Wifey Deere - Page 2 8c77dc10
Overall view of the brake setup
Wifey Deere - Page 2 Ab733b10
Checking for clearance for the wrench, I’m bad about forgetting that you need a wrench of a socket to clear not just the bolt head 😅, but this tim I remembered
Wifey Deere - Page 2 05603e10
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 10:03 am
After a little shaping it looks like this
Wifey Deere - Page 2 Fd2cbe10
Next onto this, but what is it?
Wifey Deere - Page 2 A61e8f10
After playing around with the length got the shifter arm welded on the 820 shifter so that I can get in all the gears and they line up proper with the numbers on the shift gate.
Wifey Deere - Page 2 A57e7410
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 10:06 am
Problem was there was more flex in the shifting assembly than I like, so that’s where the cube from last post comes in
Wifey Deere - Page 2 D39c7b10
I welded the cube on the old trans mount and used it to build a removable upper support for the arm, I didn’t get a picture but I made a steel bushing that bolts in the hole and the shifter arm pivots on it and greatly tighten the shifting up
Wifey Deere - Page 2 E2a54310
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 10:12 am
Since I lifted this tractor 1.25 inches I needed to move the pulley up the same amount, so I cut the center out of the 820 factory pulley and welded it to the factory John Deere rear pulley with a 1/4 inch spacer to get the right height so I didn’t have to change the clutch mechanism
Wifey Deere - Page 2 Cdc47510
MightyRaze and diddie like this post
fbisurveilancevan
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 12:52 pm
Just let me know in advance if your doing a build off because I can't keep up with this mechanic porn.
diddie
diddie
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 4:32 pm
nice heavy duty set up on the brake and shifter both.
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 5:59 pm
Thanks fellas glad you like it! I’ll hopefully be entering the build off next year if they have it again:) hope to get the front axle geometry dialed tomorrow
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 21st 2022, 10:14 pm
Nice work man! You're making good progress!
In case you didn't realize you can in fact attach more than 3 photos per post, what you do is "remove all" after you've  "inserted all" then add more, it's that's easy!
Keep up the great work!
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 23rd 2022, 9:37 pm
Thanks man I didn’t know that! But honestly I’ll prolly keep doing 3 I have trouble remembering what order I upload them in even with 3 and have to redo my captions sometimes as is 😅😅. I Have ADHD and my short term memory is trash
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 23rd 2022, 9:42 pm
I added some bracing to the front axle today that will double as a handy tie down point also if need be
Wifey Deere - Page 2 B25c2f10
Wifey Deere - Page 2 B9fec710
Wifey Deere - Page 2 B5065210
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 23rd 2022, 11:14 pm
Excellente!  The work on this rig is amazing!
PostSubject: Re: Wifey Deere   Wifey Deere - Page 2 Icon_minitimeSeptember 26th 2022, 9:09 pm
Thanks mighty! I really appreciate it! Got some more work done, used the die you see in the back round to build these cups, I’ll explain the purpose later in another post
Wifey Deere - Page 2 4a393d10
And welded on the frame, welding gods was smiling on me for this
Wifey Deere - Page 2 3f4fe610
Little nut hidden on the backside, normally I bolt through the frame but there was stuff in the way where these needed to go.
Wifey Deere - Page 2 C8ca5710
Wifey Deere
» John deere SLX 38
» John deere or Cub
» The Orange Deere
» My Dynamark 836 and John Deere 100
