 Wifey Deere
fbisurveilancevan
6 posters
Wifey Deere Empty
PostSubject: Wifey Deere   Wifey Deere Icon_minitimeAugust 28th 2022, 3:24 pm
Hi all though I might share some pictures and videos of the wife’s tractor in here
Here’s a video explaining the tractor and the recovery
https://youtu.be/5aLQ7UP8NNk
Here’s one of me getting it running after it’s abandonment
https://youtu.be/e9KCOkD-nwo
And this leads up to us riding it at Good Evening Ranch
https://youtu.be/bTII7F5v_2E
Now it’s been a great little tractor but she’s really enjoying it more than I tough she would so I decided to do some upgrades, the 801 was fine but the low gear wasn’t really slow enough for crawling, so I’m swapping in a 820, which will also be faster in top gear, gonna go from 21 inch rears and 15 fronts to 25 rears and 20 inch fronts, at the same time stretching the wheel base and making the tractor wider, which will be more stable. Gonna upload some pics later on too show the progress later
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 28th 2022, 3:33 pm
Here’s a few pics of the lift and stretch I did to get the 25s to clear the fenders, 3/4 stretch and 1 1/4 lift
Wifey Deere 6546d110
Chopped the trans mount here, slid it down and back and added a filler piece to make up the difference
Wifey Deere 9e9dd010
Buffed the welds off the outside, so it will look factory at first glance, left the inside welds alone to help with strength
Wifey Deere 98283010
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 28th 2022, 3:42 pm
Well now the tire clears the front and top of the fender but the rear lip is hitting hard, I could have cut the back lip off but it would have looked funny to me so I decided to section the fenders
Wifey Deere F4ce9f10
Before
Wifey Deere 5e418310
After
Wifey Deere F4e35e10
Mocked up with the rack that’s going on the back, I’ll have to modify the rack but I think it’s gonna look good.
fbisurveilancevan
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 29th 2022, 1:56 pm
Worked as a JD tech for a long time and I can't express my hatred for the newer models.
These older ones however just hit the right spot.
Those fenders look amazing like so and those tires just fit perfect
Might be a pain if they're full of mud though, are you perhaps still lifting the pan a little?
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 31st 2022, 8:26 am
Thanks man! This thing is built pretty good for being a lawn tractor, but I’m not lifting the fenders anymore than they are, I don’t mind if mud touches em, it will just rub off Grin
Got the trans pulled apart to lock the diff
Wifey Deere 2b889e10
Was really sad to see the shift keys was trashed Sad the tractor I bought that I took this 820 out of was a Murray in really nice shape that came with a snow plow, not running. So I’d guess they was overly aggressive and tore up the keys plowing
Wifey Deere F8547410
Decided to try a “Fozzy” locker, cleaned up the gears and then tig brazed up the gears
Wifey Deere 7b1de210
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 31st 2022, 8:43 am
Got the frame chop started, took the spare frame and got the extension pieces cut
Wifey Deere 54a76910
Built this hub puller to help get hubs off without breaking them, took these hubs right off, and they were stuck, had a 2 ft breaker bar and was leaning on it pretty hard
Wifey Deere 985b0910
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 31st 2022, 8:51 am
Played with the grinder and files till the fit up looked
Wifey Deere 51109910
Got it squared up and tacked up, been welding it little at a time and letting it cool in between.
Wifey Deere 90360910
MightyRaze, diddie, Brianator, Rustbucket Garage and fbisurveilancevan like this post
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 31st 2022, 12:43 pm
I know this is outside the quality build you got going, but I just love the name.  "Wifey Deere"
Wifey Deere 2731072446
Wifey Deere Sig115PROJECTS:
Wifey Deere Sig214Wifey Deere Sig314
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 31st 2022, 8:12 pm
Nice work man that's really looking awesome!
My All Terrain Tractors:
diddie
diddie
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeAugust 31st 2022, 9:58 pm
Nice work, I like how you sectioned those fenders going to look pretty good.
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 1st 2022, 11:53 pm
Thanks Fellas! I really like the fenders too, came out better than expected to be honest, but decided to do them a little different, they will look the same when done it’s just less welding and fitting. I felt pretty clever with the name, glad you like it too Mighty. Got some work done today on it
Got the outside welds ground down
Wifey Deere Ebd14a10
Quick coat of primer
Wifey Deere 88af4e10
And some black to finish
Wifey Deere A99a0e10
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 2nd 2022, 12:00 am
Cut the pan for the mid stretch, did 2 inches same as the frame Got some filler pieces bent up, they was a real pain because the pan tapered slightly and has a different radius at the spot I cut it (right in a transition) but tomorrow should be fairly easy the rest is just copy and paste out of the donor pan
Wifey Deere 8af18510
Wifey Deere 58eb0d10
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 3rd 2022, 11:50 am
Put a big day in yesterday, made some good progress, got the middle filler cut and tacked in
Wifey Deere 6ffe6910
Decided to do the rear fenders this way to save a weld seam plus this pan is in better shape overall
Wifey Deere 9ad59610
Another shot showing the new tire clearance 😍
Wifey Deere C6214c10
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 3rd 2022, 11:58 am
Got the rear filler unrolled and tacked in, felt pretty clever doing it this way, but turned out being a big pain in the but because I didn’t flatten it before I welded the extension on, so I had to use to hammers one as a backer kinda and pound it flat, took a long time to get a decent result but I am happy with it now
Wifey Deere Aff7f210
Sweet looking booty if I do say do myself 🥰
Wifey Deere E8bf7310
Now on to the seat mounts!
Wifey Deere 312c1210
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 3rd 2022, 12:04 pm
Seat mocked up with the mounts, still needs drilled so the seat can flip up, ended up trying a few seat pan flip mounts laying around, but had one off a wheel horse that her seat bolted right up to, so went with that one. I could have reused the leaf type springs but I really wanted a flip up seat so I can add a storage box under there for her
Wifey Deere Cd455e10
Mock up pic with the rack and seat definitely gotta cut the rack down some but it’s gonna fit nice
Wifey Deere 6fcc0210
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 3rd 2022, 10:57 pm
The seat mounts were kinda big and bulky so I drilled some speed holes in em. It was going good till somehow my math got off and the spacing got out of whack, and I went a step to far on the step bit once like every time I used the dam thing lol but thats ok it still looks ok and I don’t feel like remaking them so it will have to be good enough Grin
Wifey Deere 98403010
diddie
diddie
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 4th 2022, 9:18 pm
Great job welding up that thin metal! I can tell you have the patients that I seem to lack! lol.
Rustbucket Garage
Rustbucket Garage
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 4th 2022, 10:16 pm
Does that add 5 or 10 horsepower? I forget lol. Looks awesome! Very Happy
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 4th 2022, 11:17 pm
Thanks guys! I’m thinking it adds at least 4 hp 😂 and I don’t know if patient
is the right word, I’d go with stubborn 😂😅 anyways I got the mounts and springs in tonight, need yo add some bracing underneath for the springs but that will be a project for tomorrow
Got the seat mounted tonight, it’s a little higher than I like but it’s more work to lower it than I care to do due to the springs, but if it becomes a issue I can lower it later by drilling a couple holes and then frenching the spring mounts into the pan. Need this add some bracing under the springs on the frame but that’s. Project for tom
Wifey Deere 133d2310
Wifey Deere Cab51e10
diddie and Brianator like this post
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 9th 2022, 4:20 pm
Got some catching up to do! Got the trans prepped and locked finally, broke down and added grease zerks to the axle shafts and input bearings
Wifey Deere 078a9110
Wifey Deere 0e285110
Wifey Deere 30a8e810
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 9th 2022, 4:29 pm
So the front axle needed to be wider to get a decent steering angle out of the new much bigger front tires and also to match the new stance of the rearend. I decided to make it a “stretch” axle to add a little wheel base up front to help keep the frontend down also. So I took two factory front axles and started cutting
Wifey Deere Fe463510
Wifey Deere 51e0e010
Wifey Deere Ded71010
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 9th 2022, 4:33 pm
More cutting welding and grinding gives you this
Wifey Deere D47a4c10
But Lieutenant Dan you ain’t got no legs! 🤣
Wifey Deere 65322110
That’s better! This was definitely not the best way to do this but it came out ok but wouldn’t do the same way again
Wifey Deere 643be010
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 9th 2022, 4:42 pm
Lots more welding cutting and grinding gives you this!
Wifey Deere 85b76710
How it looks installed
Wifey Deere 97b0f910
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 9th 2022, 4:48 pm
Some stance pictures
Wifey Deere 82d23c10
[url=https://servimg.com/view/19896805/141]Wifey Deere 6570a910
Wifey Deere Empty
PostSubject: Re: Wifey Deere   Wifey Deere Icon_minitimeSeptember 9th 2022, 4:52 pm
Two more and I’m done for now, hope you like em 😬
Wifey Deere 5083c510
Wifey Deere 493a0a10
Wifey Deere Empty
Wifey Deere
» John deere SLX 38
» John deere or Cub
» The Orange Deere
» My Dynamark 836 and John Deere 100
