 RED STAG 69 Raider 12 The Best Rusty Copy
BlakeGroce
TechnoChicken
Budget_gokart
Nevadablue
Rustbucket Garage
15 posters
Go to page : Previous  1, 2, 3, 4, 5, 6, 7
ranch king pro 08
2023 Build-Off Top 3 Winner
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Empty
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeNovember 28th 2023, 12:52 am
@Crazy_Carl might be because it's late and I'm tired but that intro was funnier than it needed to be lol. Also that engraving looks mint  RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 1f44c
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeNovember 28th 2023, 3:57 am
@ranch king pro 08 If you’re into humor…have you seen?
ranch king pro 08
ranch king pro 08
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeNovember 28th 2023, 11:51 am
@Crazy_Carl oh god there's more! I'll watch those sometime today
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeNovember 29th 2023, 12:49 am
I finished up installing the winch today.  I've only got about 2-3 projects left on my list before RED STAG's next serious outing.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 368a0110
Instead of hurting myself pushing the tractor around the shop, I figured I could just pull it around with a sling to reposition the tractor depending on what exactly I'm working on.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 A32b1d10
I really like how my wiring job came out.  Hey what's going on here?! What squirrel broke into the tractor shop and took RED STAG's HEAD?!
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8612
I did not use the rocker switch assembly that came with winch kit.  I used a SPDT momentary on-off-on switch with a protective rubber boot.  I shortened the wiring harness and used heat shrink to seal up the end of the cable jacket
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8614
Before bedtime I got a little headstart on my brake line/blleeder screw guard.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8613
Hammernco likes this post
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeNovember 30th 2023, 2:45 am
I have some details left to finish, but my brake disc guard is pretty much done.🤌😎
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8616
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8617
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8615
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeNovember 30th 2023, 9:53 pm
Tonight I braced up the brake disc guard to make it stiffer and more robust. I'm considering this project done.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8618
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8619
I also created an axle cradle from a 14" 2x6 and two 2x6 blocks ripped down to 2.5" wide. Looks like something like this but a 1/2 longer could work for a Wheel Horse with a plow mount. The cradle really helps keep the tractor more stable especially when removing only the right side tire for belt maintenance.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8620
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8621
MightyRaze and Hammernco like this post
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeDecember 6th 2023, 9:58 pm
Well today I finally executed an idea from a very old Creepy Crawler video where you drill the rivets out holding your idler pulley together to replace the bearing.  I picked up a nice Italian made SKF bearing from Napa for $13.  I scrounged some hardware from work and made it happen.  The quickest and easiest way for me to drill the rivets was to skip center punching, just line up the center drill, after drilling with the # 3 center drill, I dusted the head off with a 3/8 drill.  I did this all in the drill press.  I assembled with lockwashers and blue locktite.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8714
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8811
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8810
MightyRaze, Brianator, PizzaKitty26 and Hammernco like this post
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeDecember 9th 2023, 6:29 pm
Well after upgrading my Mac OS so I could run FreeCad and make a template for a 5 on 4.5" bolt hole circle to re-drill my brand new ALUMINUM RIMS, RED STAG has a new pair of shoes! 25x11-10 ITP Mudlites to be exact. I like the trusted mud performance and how squishy they are. Danceparty
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8813
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8814
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8812
Then I used some scales to weigh what the tractor weighs with me on it with the help of my Dad to read the scales and it comes to a light 665 lbs with rider with a 100 lb difference between the front and rear axles. This doesn't include the toolbox or beers in the trunk lol.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8815
MightyRaze, Brianator and Hammernco like this post
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeDecember 9th 2023, 8:45 pm
Love mudlites! I had a pretty bald set bouncing around between mutt, budgie, and the gt6k. Just good all around tires. Tried some 25x11-10s on mutt and they did good even though I couldn’t run them too low for fear of falling off the bead. Even the cracked up 26x12-12s that are on the gt6k right now are good performers. Those new rims are real sharp too!
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeDecember 9th 2023, 11:47 pm
Love the attention to detail and the new tires and rims!
ranch king pro 08
ranch king pro 08
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeDecember 10th 2023, 12:19 pm
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_8810 gotta love the safety crocks. OSHA would be mad they're not in sports mode CryLaugh
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeFebruary 15th 2024, 4:07 pm
I did a very small mod today and just added a couple U-bolts to the dash tower to give the bungee cord that holds the hood shut a permanent place to hook onto.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9310
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeFebruary 15th 2024, 4:50 pm
Your factory hood latch not work well?  I've found that mine works very well.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Sig115PROJECTS:
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Sig214RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Sig314
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeFebruary 15th 2024, 8:52 pm
@MightyRaze it’s really worn out and barely works, plus when the frame twists just right it pops the hood open.
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeMarch 2nd 2024, 7:12 pm
Red Stag is back in action after getting my head ported and shaved by captain315, she fired right up and runs great on 93 now, it runs very smooth like a Japanese motorcycle, it seems to have more power because if I let the clutch out slowly in third while idling she just chuggs right along, I’m looking forward to a real test out at the farm hopefully soon
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9412
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9410
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9411
MightyRaze and RichieRichOverdrive like this post
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeApril 11th 2024, 5:39 am
I finally got out and did some riding this past weekend!  I've been waiting so long to test out my new rear wheels and hydraulic disc brake.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9511
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9510
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9512
I really like the performance of the mudlites.  The hydraulic disc brake with a functional OEM parking brake is one of my favorite mods over.  However, I encountered an issue with my clutch slipping in deep water. I had to move the spring location in the back because the caliper was in the way.  However this was a bad angle of pull on clutch arm so it lost mechanical advantage.  So I added a metal piece onto the clutch arm with adjustable positions so the spring has more mechanical advantage when the clutch is fully engaged.  I'm looking forward to testing this out soon along with a new belt rear belt keeper bolt I've added.
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9513
RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Img_9514
PostSubject: Re: RED STAG 69 Raider 12 The Best Rusty Copy   RED STAG 69 Raider 12 The Best Rusty Copy - Page 7 Icon_minitimeApril 11th 2024, 8:12 am
Nice clutch adjustments.  LOL.
Page 7 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7
» Ole Rusty Red **(UPDATED)**
» Rusty Metel #2
» 1980 MTD 918 - 'Ol Rusty!
» Walbro LMT Chinese copy carbs, any good?
» Rusty red (wheel horse C105)
