| I need to extend my rear axles | |
craftsman30mph Member
Age : 32 Join date : 2011-08-23 Points : 5032 Posts : 127 Location : branch MI
| Subject: I need to extend my rear axles September 22nd 2011, 12:55 am | |
| well the way I'm building my tractor I am putting 5 bolt hubs and wider tires on the back but I need it to be wider than just putting 5 bolt hubs on it and wider tires cuz I'm doing that and I still need it wider so i need to extend my rear axles somehow any ideas?? I have a 5 speed peerless tranny if that helps give you ideas idk. please help!! thank you | |
Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5471 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: I need to extend my rear axles September 22nd 2011, 11:45 am | |
| Well you could build some offset hubs, or you could do like me and swap out the short rear axle for a long one from a parts transmission, and then offset the whole thing in the frame to center the wheels. Only down side is that stock mower axles tend to snap under heavy abuse (like I did lol) | |
| Subject: Re: I need to extend my rear axles September 22nd 2011, 11:55 am | |
| - Ford Boi wrote:
- Well you could build some offset hubs, or you could do like me and swap out the short rear axle for a long one from a parts transmission, and then offset the whole thing in the frame to center the wheels. Only down side is that stock mower axles tend to snap under heavy abuse (like I did lol)
yeah I thought about doing the last one you said and then bracing a spacer to the frame so it could still spin on the axle but would still hold it up and keep it supported so it didn't snap off | |
Ford Boi Member
| Subject: Re: I need to extend my rear axles September 22nd 2011, 12:49 pm | |
| I got about 7 months out of mine before it broke.... This time I am making a brace for it. Because otherwise it works very good. Kinda looks funny with the transmission off to one side but then again a mower with huge tires on it kind looks funny anyway lol | |
| Subject: Re: I need to extend my rear axles September 22nd 2011, 1:23 pm | |
| - Ford Boi wrote:
- I got about 7 months out of mine before it broke.... This time I am making a brace for it. Because otherwise it works very good. Kinda looks funny with the transmission off to one side but then again a mower with huge tires on it kind looks funny anyway lol
how much more width did you gain? i need to get to about 45 inches with mine | |
Ford Boi Member
| Subject: Re: I need to extend my rear axles September 22nd 2011, 5:56 pm | |
| I'm not sure exactly....Do you need 45" from axle tip to tip? I can measure mine when I run back in the shed. | |
| Subject: Re: I need to extend my rear axles September 22nd 2011, 6:51 pm | |
| - Ford Boi wrote:
- I'm not sure exactly....Do you need 45" from axle tip to tip? I can measure mine when I run back in the shed.
I just need 45 inches from outsides of the tires | |
fetters18 Member
Age : 27 Join date : 2010-12-18 Points : 5166 Posts : 59 Location : ohio
Ford Boi Member
| Subject: Re: I need to extend my rear axles September 23rd 2011, 8:04 pm | |
| I measured mine and I think it was 45" outside of tires. I forget exactly now. 32" from axle end to end. I just have ATV rims with mower hubs welded to plates inside, crude but works lol.... | |
Age : 54 Join date : 2010-02-10 Points : 7079 Posts : 1726 Location : Florida, USA
| Subject: Re: I need to extend my rear axles September 24th 2011, 4:42 pm | |
| Possibility is to get some 8" round steel pipe ( size of the rims mounted to the axle) - weld that to the end of the tractor rims, then weld the outer wheels back on, to reinforce the axle shafts for extended weight further out, use a piece of black pipe over the axle ( slides over and axle can still turn) with a bracket to the frame solid mounted - id add a zerk fitting to the pipe so can be greased from time to time.
Would be easier then expensive adapters and messing with the trans/axles. | |
arild365 Member
Age : 29 Join date : 2010-02-11 Points : 5816 Posts : 320 Location : Canada, BC
| Subject: Re: I need to extend my rear axles September 25th 2011, 12:41 am | |
| just remember tho. his rear end is a solid sears suberban (i believe) rear end. Those newer craftsmans arnt built as solid and his tractor has 1" axles as yours has 3//4' I bet if you put some sort of support you might be able to do it. good luck! cant wait to see what you come up with!
Arild | |
| Subject: Re: I need to extend my rear axles September 25th 2011, 12:06 pm | |
| - arild365 wrote:
- just remember tho. his rear end is a solid sears suberban (i believe) rear end. Those newer craftsmans arnt built as solid and his tractor has 1" axles as yours has 3//4' I bet if you put some sort of support you might be able to do it. good luck! cant wait to see what you come up with!
Arild yeah I plan on making some type of support to the frame if I do this | |
