so i go under my tractor for the first time since the ride and i get greeted by half a quart of oil under the tractor still dripping, since the tractor was still muddy, i could see that it had all leaked out of my brake shaft, which means that the seal went bad, so i found a crossreferenced seal online, i couldnt get the brake drum off without a puller, which i couldnt fit in there without dropping the trans, which i really didnt want to do, but i dropped the trans, and then i realized that i should take the shifter off to look the oil, and it looked like mud water, and i probably ran it like that for 3 hours at the offroad park in 3rd high, so thats where im at now
Age : 49 Join date : 2016-09-06 Points : 15680 Posts : 10989 Location : Oklahoma
It's nice these tractors used many automotive seals. It makes it easy to replace many of them due to this. I don't remember, but I believe I had to replace my ST/16's when I did that brake on mine. Mine was a bit oily back when I worked on mine.
The transaxle problems are completely fixed. I also installed e3s and found out there was a air fuel adjustment on my carb so I adjusted that and now I have virtually no bog during take off even in 3rd high and I have better throttle response and it used to bog or die at about 5/6 throttle and up but now it doesn’t. Overall it has alot more torque and added an extra 1 or 2 mph to the top speed
MightyRaze, Brianator and MN mudder like this post
TheJakeOfJake Member
Join date : 2020-11-08 Points : 1588 Posts : 100 Location : Atlanta, GA
For Christmas I got a winch and a pair of atv tie rods. I had to trim them a little bit to be the right length, the winch works and is mounted. Since I have a long front bumper I was able to mount the control box behind the winch
Me and my dad might be building a tractor together and it might be a build off participant, id do this so he can have something to ride instead of just sitting in the car while I'm there, I just am trying to convince him to buy one
Brianator Moderator
Age : 45 Join date : 2019-07-02 Points : 4551 Posts : 2385 Location : Ontario, Canada
yes i did use it. when i backed it out of the garage yesterday to reanforce the spindles, it was making a horrible squelling sound. when I took off the front wheels, there was very little grease and only inbetween the bushings where it wasnt doing anything. I think i forgot to grease it after 2 times of being underwater for more then 5 minutes
Even with grease, the bushings will produce heat and "thin" down the grease. Going in water is a quick quinch and will blow and wash out the grease. Dirty water will scrub it out as well.
