 GT 18 mud mower build
Nevadablue
Fastman
Budget_gokart
Rustbucket Garage
Northwest_Ohio_Mud_Mowers
yeethaw
TheJakeOfJake
14 posters
Go to page : 1, 2, 3, 4, 5, 6  Next
TheJakeOfJake
TheJakeOfJake
GT 18 mud mower build Empty
PostSubject: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeNovember 20th 2020, 1:30 pm
I picked up a 1984 craftsman gt 18 oppy 6 speed for 100 bucks for a mud mower build
GT 18 mud mower build Img_0010
GT 18 mud mower build Img_0011
GT 18 mud mower build Img_6010
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeNovember 20th 2020, 1:31 pm
GT 18 mud mower build Img_0012
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeNovember 20th 2020, 1:32 pm
when i shift to high range it doesnt shift it just rattles does anybody know how to fix that
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeNovember 20th 2020, 4:05 pm
@AllisKidD21 has some knowledge of the internals.  Maybe he will pop in.
GT 18 mud mower build Sig115PROJECTS:
GT 18 mud mower build Sig214GT 18 mud mower build Sig314
yeethaw
yeethaw
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 3rd 2020, 1:19 pm
can you take some pictures of where your hi and lo shifter is at? Ive got almost the same tractor but im pretty sure that mine is a three speed without hi lo.
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 6th 2020, 8:48 am
it turns out i was already in high range and it wouldnt sh*t to low because there was junk on the pin so i have to pb blaster the crap out of it and now it works
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 6th 2020, 10:03 pm
Glad you got it figured out!
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 7th 2020, 4:30 pm
So the next mod i think im going to do is a pulley swap . It is a vertical drive but the engine pulley is on the back of the engine and i think its held on with four bolts. the trans pulley is tucked really close to the frame. I think i want to swap the front pulley to the same size as the trans pulley because it will be easier
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 8th 2020, 8:03 am
So I am looking for the best rear tires for my sitiuation. since i will be riding through my yard alot i dont want something that will tear up the grass but i will also be at the trails so i want something grippy. what are the best tires for this
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 8th 2020, 9:11 am
Repetitive driving in one spot will tear up the yard. Even on the turf savers.  I'm not an expert, but I have seen several over time use a Deestone D930 type tire. It would be an upgrade but maybe still mild enough to not tear the yard too bad.  Not sure if they make a knobby in that would fit your rims.
GT 18 mud mower build Deesto10
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 8th 2020, 9:14 am
do knobbies work in mud
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 8th 2020, 9:23 am
Better than a turf.  If you are wanting to go through lots of mud, you would need a more aggressive tire and a locked rear end for best results.  Then be careful in the yard.  :-)
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 8th 2020, 9:43 am
@MightyRaze what about if you grove the turfs?
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 8th 2020, 10:51 am
It helps with traction for a budget build!  Lots of work, but doable.  I did it once myself!  I think there are a couple I have seen out there that run them all the time.
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 8th 2020, 11:16 am
@MightyRaze I want my tractor to be able to go to haspin and I don't have the money for new tires so I will grove the turfs and put a winch on it and see what happens.
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 8th 2020, 8:44 pm
If haspin is dry, turfs could get through it. Grooved even better. I would recommend locking the rear. Hills can be sketchy, even dangerous on open diffs. Opposite wheel brakes traction and you are out of control quick.
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeDecember 9th 2020, 7:55 am
Thanks @MightyRaze I will do that
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeMay 21st 2021, 3:10 pm
Time to revive this sucker.
This tractor has been sitting under a tarp since christmas. it had gone down the priority list. now i have regained the motivation. now i have list of mods to make. say if i have anything to add or something i should have
pulley swap
lock rear end
rear ag tires
bigger front tires
skid plate for front axle and for transaxle
front and rear bumper
hand brake
gas pedal
i think thats it
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeMay 21st 2021, 11:01 pm
Glad to see this pick back up!   Very Happy
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeMay 22nd 2021, 1:45 pm
has anyone every pully swapped a 633a 6 speed high low
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeMay 22nd 2021, 5:13 pm
The pulley shaft is tapered so you would need to cut the hub out of the pulley to put on the new one. On mine I just put a biggest or bigger engine pulley I could get away with.
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeMay 22nd 2021, 9:58 pm
I was planning on swaping the engine pulley because it seemed alot easier i was just wondering if that transaxle could hold up to a pulley swap
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeMay 22nd 2021, 10:43 pm
Yeah it should hold up.
TheJakeOfJake
TheJakeOfJake
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeJune 6th 2021, 9:52 am
@MightyRaze What ratio did you pully swap yours to and how fast did it go
PostSubject: Re: GT 18 mud mower build   GT 18 mud mower build Icon_minitimeJune 6th 2021, 6:15 pm
@TheJakeOfJake
I had a 9 inch engine pulley when I had the hotrod craftsman.  I wouldn't recommend it for a mud build.  I got pretty close to 30ish.  I'm going to shoot for a 6 or 7 on my build next year.
Stock trans pulley.
Page 1 of 6Go to page : 1, 2, 3, 4, 5, 6  Next
» 4x4 Mower Build
» Mud mower build
» Mud mower build
» Mud Mower Build
» LT 1000 ATV Mower Build
