 My Homemade Trailers
Fastman
TechnoChicken
Budget_gokart
Nevadablue
BlakeGroce
12 posters
My Homemade Trailers - Page 2 Empty
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeDecember 19th 2021, 2:33 am
I agree with BlakeGroce about the welding stuff. Making sure you have clean metal is pretty important. Rust and paint ect can mess up welds, especially rust. Then once you get the hang of it, you can make pretty nice looking stuff. I weld something probably once a week at a minumum, so after awhile you get a good feel for it, but even then sometimes there's some impurities or something that messes up your weld, even if it looked clean. Just happens.
That trailer looks pretty good so far.
BlakeGroce and TechnoChicken like this post
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeDecember 23rd 2021, 12:53 am
Started working on mounting the front bed support to the frame!
I ended up moving the original holes down and cut off the top since it wasn't needed anymore.
My Homemade Trailers - Page 2 20211220
I also made some bushings to weld in the frame to keep the square tubing from crushing when I tighten up the bolts. I made them out of an oil pump drive from a Kohler courage engine. All I had to do was cut it down, drill out the existing hole to 5/16 and bevel the ends to give a good spot to weld. Worked out pretty slick!
My Homemade Trailers - Page 2 20211222
My Homemade Trailers - Page 2 20211221
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeDecember 23rd 2021, 1:02 am
Here's some pictures of how those bushings work. Once you get them all welded up and grinded down you'll never know they're even there! ...........But you and I both will!  Wink
My Homemade Trailers - Page 2 20211224
My Homemade Trailers - Page 2 20211223
My Homemade Trailers - Page 2 20211225
MightyRaze, Brianator and Nevadablue like this post
Nevadablue
Nevadablue
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeDecember 23rd 2021, 3:12 pm
Those bushings are slick. Now all I have to do is remember it.
BlakeGroce likes this post
Fastman
Fastman
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeDecember 23rd 2021, 7:41 pm
BlakeGroce wrote:
Also got the axle carrier squared up and welded in!
My Homemade Trailers - Page 2 20211218
My Homemade Trailers - Page 2 20211219
My Homemade Trailers - Page 2 20211217
one question, whats under the tarp? (im a car guy my first truck and only vehichle i have ever had is a 1950 ford f100)
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeDecember 27th 2021, 9:20 pm
@Fastman That would be my 74 Plymouth Satellite (just bought it)
My Homemade Trailers - Page 2 20211018
My grandfather has a 1950 Ford f1 as well! Cant beat em!
My Homemade Trailers - Page 2 19227110
I also have a 67 Chevy C10 (that's my daily driver)
My Homemade Trailers - Page 2 Img_8210
Rustbucket Garage, Fastman, Nevadablue and MN mudder like this post
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 1st 2022, 1:27 am
Update: Cut down the back plate to that front support since it wasn't needed anymore!
My Homemade Trailers - Page 2 20211228
Also made a whole bunch of tabs to weld on the frame for my wood to attach to. Made them out of a piece of cold formed angle iron (a little less than 1/8th inch thick), cut it down into 1 inch wide pieces and then drilled a 5/16 hole in all of them! Wanted them to be light weight and they don't have to be structural.
My Homemade Trailers - Page 2 20211230
My Homemade Trailers - Page 2 20211231
My Homemade Trailers - Page 2 20211229
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 1st 2022, 1:38 am
Here's a picture of all of those tabs welded to the frame. Have them on both the front and the back side, gonna use carriage head bolts to hold the wood down!
My Homemade Trailers - Page 2 20211232
Nevadablue likes this post
Nevadablue
Nevadablue
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 1st 2022, 1:15 pm
Good idea on the carriage bolts. If you ever want a completely flat bolt for wood, look for elevator bolts. They sink down completely into the wood.
My Homemade Trailers - Page 2 8f7e5510
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 3rd 2022, 12:43 pm
@Nevadablue Wish I would have known about those before I bought a bunch of carriage head bolts.  pale  Would be nice to not get the shovel caught on the head of the bolts.
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 3rd 2022, 1:29 pm
Well I got my pieces of 2 inch wide, 1/8th inch think angle iron welded on all four corners, this will give me a place to mount my side boards to!
My Homemade Trailers - Page 2 20211233
I also got all the wood boards cut to length and fitted. I'm using used deck boards that my papaw gave me, they're pressure treated so they should last a good while!
My Homemade Trailers - Page 2 20211235
My Homemade Trailers - Page 2 20211234
My Homemade Trailers - Page 2 20211236
MightyRaze, Nevadablue and MN mudder like this post
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 3rd 2022, 6:58 pm
Nice Job! I'm really diggin' the look of the wood
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 4th 2022, 9:26 am
Thanks Carl!
Ever have one of those moments when you plan something in your head and then when you go to do it you realize that there is no way that your plan is going to work? Well I ended up having to re-think how I was going to attach the front boards since my original idea was not going to work at all. I ended up having to make some tabs out of some pieces of 1/8th inch steel to attach and hold those front boards on.
My Homemade Trailers - Page 2 20220113
My Homemade Trailers - Page 2 20220114
My Homemade Trailers - Page 2 20220115
Nevadablue
Nevadablue
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 4th 2022, 3:07 pm
Nice recovery. It looks like you planned it that way.
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 7th 2022, 12:11 pm
It's looking awesome and very sturdy, nice work!
My All Terrain Tractors:
BlakeGroce and Nevadablue like this post
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 7th 2022, 9:06 pm
Thanks guys!
Got the frame all primed the other day. I'm using Rustoleum rusty metal primer and I'm brushing it on so it's been taking a while for it to dry being the middle of winter. But it's turning out pretty good so far......nice and thick so it should hold up good!
My Homemade Trailers - Page 2 Screen19
My Homemade Trailers - Page 2 20220118
My Homemade Trailers - Page 2 20220119
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 11th 2022, 2:05 pm
Well I got the frame of the bed all painted! Ended up putting 2 coats on it. Used Rustoleum gloss black.
My Homemade Trailers - Page 2 Screen20
My Homemade Trailers - Page 2 20220121
My Homemade Trailers - Page 2 20220122
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 13th 2022, 10:50 am
So this is the mechanism that allows the bed to dump and the handle is all bent out of shape! It's bent right where the manufacturer bent out a small piece to use as a stop. The handle was bent down and also left.
My Homemade Trailers - Page 2 20220125
My Homemade Trailers - Page 2 20220124
I bent it back the best I could left to right but as far as getting it bent back up I couldn't figure out how to do that without twisting the handle and I don't have an oxygen and acetylene torch so I just called it good enough.
My Homemade Trailers - Page 2 20220126
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 13th 2022, 11:01 am
After I got it decently straight........ish, I ended up welding in a small peice of steel to fill in that gap and to hopefully prevent it from wanting to bend again.
My Homemade Trailers - Page 2 20220127
My Homemade Trailers - Page 2 20220129
My Homemade Trailers - Page 2 20220128
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 13th 2022, 11:06 am
My Homemade Trailers - Page 2 20220130
My Homemade Trailers - Page 2 20220131
My Homemade Trailers - Page 2 20220132
Nevadablue
Nevadablue
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 13th 2022, 1:00 pm
Good job on the repair!
If you ever need to heat something like that for bending or shaping, charcoal will do it. Build a nice pile of charcoal fire in the BBQ or a hole in the yard or whatever. Then stick the metal in the middle of the pile. You should be able to get something like you are working on up to red heat with little trouble. Then beat it into the shape you want.
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 13th 2022, 3:17 pm
Hmm never thought about that before scratch  ...good idea
I also put a coat of used motor oil on the wood. Put it on nice and heavy so it soaks in good!
My Homemade Trailers - Page 2 20220133
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 13th 2022, 3:44 pm
Some people take a torch and scorch the wood to help protect.  But, if it works!  My Homemade Trailers - Page 2 1f603
My Homemade Trailers - Page 2 Sig115PROJECTS:
My Homemade Trailers - Page 2 Sig214My Homemade Trailers - Page 2 Sig314
TechnoChicken
TechnoChicken
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 13th 2022, 5:36 pm
I believe that would be fire-hardening?
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 14th 2022, 9:26 am
Trailer looks sturdy Blake! Definitely an heirloom piece.
I keep an old paint sprayer for spraying trailer decks and hay wagons with used motor oil. I used to use used motor oil for cutting oil when drilling or cutting metal but I've been told inhaling motor oil smoke is a really good way to get cancer, so I sort of stopped using it for that.
BlakeGroce
BlakeGroce
PostSubject: Re: My Homemade Trailers   My Homemade Trailers - Page 2 Icon_minitimeJanuary 14th 2022, 2:09 pm
I've came to the conclusion that everything gives you cancer.......especially in California lol! But I've always used motor oil for drilling holes.
Got all the other parts completely painted!
My Homemade Trailers - Page 2 20220134
I also made a new washer that the spring hooks to instead of painting the old one.
My Homemade Trailers - Page 2 20220135
» Add subforum under Tractor Project Builds for Accessories/ Implements/ Trailers?
» Homemade 4WD
» Homemade GoKart
» transaxle for homemade utv
» Homemade Thread ( if it cost to much so you made it yourself, please show it off here!)
All-Terrain Lawn Tractor Forum :: Accessories / Implements / Trailers :: Trailers-
