So through a trade deal, I'm repairing my cousin's dirt bike and atv and in return I required back my homemade go kart. It doesn't have a clutch right now but I'm debating whether to just throw a centrifugal back on it or go with a torque convertor.
Get your machine shop buddy to bore out a chunk of keys shaft, V the end of the existing crank and the new piece, run a bolt through into the existing shaft, line them up with a key. Use a good bushing with a hole in it to keep it strait, use the hole to zap a few tack welds with the tig. once tacked in and strait, weld a little here, weld a little there, let it cool off and repeat! Crude.... but it would totally work.
Crazy_Carl Veteran Member
@TheBeal I may just have to do that. I also have an interference dilemma I need to figure out with the chain and CVT. I pressure washed it, fixed the flat tire, moved the seat backward and figured out the top speed will be 28 mph.
Today I cut the motor mounting plate loose and built a mount from bed frame angle iron to relocate the gas tank. Now there's plenty of room for the CVT if it ever gets here.
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2853 Posts : 582 Location : Reeses Mill, WV
Nice! If you paint it white and put one of those radio antenna things that looks like a satelite dish on the front on a pole, you'd have a mini lunar rover.
Nah black rims on silver hubs. One advantage of a CVT is the engine braking, I"ve barely had to use the band brake in testing. I need to take it out to the farm soon for a real test. The frame is really heavy 1x1x11gauge.
Worked on some more finishing touches. I was troubleshooting the CVT. It needed just another 100 rpm to fully shift up so I just bent a little tab on the throttle plate and that worked well. I installed a fuel filter, duct tapped up the tear in the seat, welded on a tab to re-connect the brake bracket to the frame, installed the fenders and notched out the clutch cover for the chain. It rides bumpy so going to try 3 psi in the tires. I want to give this a few good laps out at the farm and do a top speed test before I pull the motor and touch up the paint.
@MightyRaze So I've actually measured the RPM of the axle with one of my tachometers, did some math and got 28mph! which is what I calculated in one of my videos. I'm dying to see what the Top speed app says though.
