| Need help i want to pulley swap my offroad mower | |
Jimbob jones New Member
Age : 27 Join date : 2019-10-20 Points : 1861 Posts : 1 Location : South kingstown RI
| | | | MightyRaze Administrator
| Subject: Re: Need help i want to pulley swap my offroad mower October 20th 2019, 9:25 pm | |
| A good pulley swap for you would be a 1:1.
Maybe a 6 inch on both ends? Maybe 5. Engine should be a 1" bore. Transaxle input I think is a 5/8". Maybe one of the guys will jump in and correct if I am wrong.
That's if it is an MST or Peerless. Not sure if a Spicer, if it is the same? | |
| Subject: Re: Need help i want to pulley swap my offroad mower October 21st 2019, 12:56 am | |
| Should stick with 5" to 5". 6" makes using the stock clutch a real pain in the neck. You can buy pulleys and hubs at TSC and weld them together, then it's a matter of finding the right size belt and adding belt keepers as needed.
Mighty you should be right on shaft sizes. | |
| Who is online? | In total there are 68 users online :: 0 Registered, 0 Hidden and 68 Guests
