| 1973 110 john deer puller | |
+8Murraymountain MightyRaze prancstaman Destructive Double W Cross Ranch AllisKidD21 TheBeal Kyracer13 12 posters |
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 11th 2019, 10:18 pm | |
| The positive wire from the coil should go to the ignition post on the key switch, that will send 12v to the coil when the key is on.
Also, with the fuel pump bolted to the heat sheild, isn't there a possibility you will have issues with vapour lock? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 11th 2019, 10:37 pm | |
| Not sure if u thank I need to move it I will I'll make a bracket to hold it and space it out off the heat shield
So if the coil goes to the key the 12v on the voltage regular goes to pos on battery then | |
prancstaman Veteran Member
| Subject: Re: 1973 110 john deer puller August 11th 2019, 11:46 pm | |
| For the fuel pump, just put nuts on the back of the fuel pump mounting bolts, then bolt it to the heat shield. The air gap made from the bolts on the back side should prevent any kind of vapor lock. | |
Kyracer13 Member
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4432 Posts : 2178 Location : North Carolina
Kyracer13 Member
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4059 Posts : 870 Location : Phillydelphia
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 19th 2019, 7:49 pm | |
| I read the rules a few time and even printed them off no were does it state a size but does say that ag tires are allowed so going to try it lol But I got around to putting the hood in primer I'll block sand it tomorrow and start shooting some color | |
| Subject: Re: 1973 110 john deer puller August 19th 2019, 10:07 pm | |
| That came out nice. Going to look great with color. You going to replace the Deere stickers? | |
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 19th 2019, 10:23 pm | |
| I had a buddy cut me some letters for it I'm going to paint the hood green with bottom inch and 1/2 yellow with silver pin stripe and black letters | |
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 20th 2019, 5:56 pm | |
| Well the hood is block sanded probably be tomorrow before I shoot any color weather kind of crap today | |
| Subject: Re: 1973 110 john deer puller August 20th 2019, 6:31 pm | |
| Looks like you did a great job fixing up the damage to the hood. Nice work! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 21st 2019, 4:43 pm | |
| I ended up shooting the yellow last night came home today tape off the yellow for the stripe and shot some green | |
Kyracer13 Member
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 21st 2019, 9:42 pm | |
| She surely is beautiful now! Great work! I see a nice Ranger in the background... | |
Kyracer13 Member
Kyracer13 Member
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 22nd 2019, 8:49 pm | |
| If u look in the pic the hood has a few spots I'll have to touch up before I wet sand the whole tractor and shoot clear on it all damn cats if they wasn't such good mice hunters they be gone lol | |
| Subject: Re: 1973 110 john deer puller August 22nd 2019, 9:12 pm | |
| She's looking great! Did you ever have an idea for front tires? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Kyracer13 Member
| Subject: Re: 1973 110 john deer puller August 22nd 2019, 9:25 pm | |
| Ah, haha. That should be neat!
Just to clarify.. is it gonna be a genuine tricycle front end or a narrow front row crop style? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Kyracer13 Member
