 [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]
tater195
diddie
muddstir
Hillbilly Homer
Hillbilly Offroading
21 posters
Go to page : Previous  1 ... 6 ... 9, 10, 11 ... 15  Next
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Empty
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 7th 2019, 11:03 am
Looks good and straight. Nice job on the spindled. In your mock-up... Your axle going to be that far forward?
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 8th 2019, 11:45 pm
Thanks fellas. The axle was a bit farther forward in that mockup than I planned on it being.
Speaking of which, I got to some more front axle work on the weekend.
Here are the bumper brackets I showed earlier in the thread:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190738
Planned on turning those into the frame mounts. After some mock-up, measuring, and cutting, they look like this:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190739
They fit right along the frame under the footboards and got welded directly to the frame in a few spots.
I decided to use some automotive inner and outer tie rod ends for the main rods of my wishbones. I drilled and tapped the ends for 5/16" bolts, I figured on having the bolts go right through the axle:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190740
Drilled the holes through the axle and bolted them up!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190741
Then I got the wishbone frame mounts welded in place:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190742
Pretty happy with how they fit along the frame!
Trimmed the bottoms up a bit so they didn't look so goofy, haha.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190743
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190744
Also made some angle steel braces for them so they wouldn't bend sideways:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190745
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190746
Should be nice and solid!
Then, after a little trick with a piece of angle steel, she held up on four wheels for the first time!!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190747
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190748
Oh yeah!!! Hahaha.
Still seems to be enough clearance for decently sharp steering, I'll definitely be making some steering stops though.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190749
Pretty happy about the way it's going so far! Also, just to be clear the radius arms are not finished yet. These are only the main rods. I still have to do the upper rods and make the mounts to attach to the top of the axle. Once I do that the caster will be under control. After that I can get the steering arms and a tie rod made up, and then I can work on getting the springs mounted up to the axle and the frame.
Either way, I'm really liking how she's sitting now!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190750
Let me know what ya think!!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 9th 2019, 9:00 am
YES!
Looks great AK.  Looks like you will need some steering stops there, but like you said steering will be fine!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Sig115PROJECTS:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Sig214[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Sig314
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 9th 2019, 9:42 am
I assume you're using coil over shocks? How big are they? I mean, if your not going off road with 'er then you definitely won't need anything crazy like what's on the MTD. Then again you're the suspension expert and half the suspension stuff yall talk about... I don't even know what it is. This'll probably be a learning lesson for me lol.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 9th 2019, 10:12 am
Judging by what I see.  I figure a leaf spring in the front.
Its a rat rod!!!!  I'm seeing something like this...
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 1939-f10
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 9th 2019, 10:22 am
Thanks Mighty! Yep definitely gonna add some steering stops in there! Also you are close on the front end. I am using leaf springs, just in a different orietation, haha.
Nope, no coils or coilovers on this one. I have a main leaf spring from a trailer I'm going to cut in half and use for a 1/4 elliptic leaf setup. "Half leaves" in other words. It was covered further back in the thread. Smile
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 9th 2019, 12:06 pm
Ah okay. Just wondering... Wouldn't look right with those coil overs. It's coming along real good though, matter of fact, now that all the build off rigs are taking shape and we can get a feel of what they are, I'm betting that this one's gonna be a winner!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 14th 2019, 12:11 am
Well thanks! I appreciate it!
I went back to work on the wishbones today, first I fabbed up some upper links:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190780
Then I made a couple mounts to be welded to the front axle:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190779
Mounts welded on:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190781
Then the first wishbone all done!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190782
Sorry for the dark pictures, but here's the setup after I got it all welded up:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190783
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190784
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190785
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190786
Didn't turn out too bad if you ask me!
Now, for a couple full four wheel pictures!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190787
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190788
Oooh I'm getting excited now boys! Hahaha.
I'm really liking the way it's looking now! I fought with the adjustments gor a while when I was trying to tune the geometry in, but I finally got it to come around and it's nice and true now!
I think tomorrow I can get the tie rod and steering arms figured out, after that I can get the axle centered, and hopefully get the springs rigged up! This is where is gets good... lol!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 14th 2019, 8:48 am
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Giphy
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 14th 2019, 5:08 pm
The front axle looks great mounted up. This is fitting your theme perfectly! I'm glad the drive shaft worked out too.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 14th 2019, 10:35 pm
Thanks Carl! Good to see you're still hanging around.
So first thing I did today was get some steering arms and a tire rod made up for my front axle:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190789
I was planning on having the tie rod out front but it didn't end up working so great, so it went behind the axle. Turned out pretty good and the Ackerman angles are perfect!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190790
It does come a bit close to the grille, but I don't think it'll become an issue. Worst case scenario I can move the grill back a bit.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190791
Should work good!
Another thing I did was finally get the upper transaxle mount installed. I've been meaning to do it for a while now and I finally got around to it:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190792
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190793
Pretty simple. I'm just glad I remembered to do it before the first test run, haha.
Also, here are a couple more shots of it in the daylight:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190794
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190795
I'm definitely liking it! I would've done the springs today too, but it was too darn hot out for any more messing around. So this is where I stopped, haha.
Still pretty good progress though! Let me know what ya think!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 15th 2019, 8:45 am
shaping up, got a long low stance, I forget if you said what tires you are running in the back? Keeping those or going bigger?
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 15th 2019, 5:33 pm
Thanks mrshaft! I'm gonna be running another set of turfs on the back that are in better shape, but are the same size as these. 18.5" I belive.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 16th 2019, 5:52 pm
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Oooooo10
Oh this is looking great!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 16th 2019, 6:32 pm
Hey thanks Beal!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 16th 2019, 8:00 pm
What type of headlights are you gonna use?
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 16th 2019, 8:23 pm
Well as I said to Rich I'm not positive that I will have lights at all, being that I won't be running a battery in this tractor.
I might throw something behind the headlight sockets though, maybe like some sheet steel ground down to bare metal and clear coated. Just something to make it look a little meaner in the front, haha.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 17th 2019, 8:51 am
Are you gonna put the lenses back in?
diddie
diddie
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 20th 2019, 10:50 pm
Been a minute since iv'e checked your build gave me a lot to check out. love that front suspension. keep up the good work !
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 21st 2019, 11:09 pm
Thanks! I appreciate it!
Destructive
Destructive
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 22nd 2019, 12:43 pm
Looks like this one is gonna be epic Smile Nice build!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 22nd 2019, 1:02 pm
I just had a funny thought. I just remembered the "Pissed -n- Broke" piston from the old Toro.  Hang that guy out one of the headlights.  LOL
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeJuly 22nd 2019, 10:08 pm
Thank you! I sure hope it turns out okay, haha.
Hahaha, yeah that might look interesting. I still have the piston too!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeAugust 10th 2019, 2:37 pm
Okay fellas, spring time is here! Leaf spring that is.
I decided to get at my spring setup today, and I made some pretty good progress! First step was to cut the spring in half so I could figure where everything would go:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190822
After some mock up I ended up cutting an additional 2 1/8" off each leaf.
Took a couple more old shackles and cut them in half to be used for the axle leaf mounts:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190823
I also installed new bushings in the leaf eyes, so everything's nice and tight now.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190824
Then after some more mock up, some measuring, and some welding, we have leaf eye mounts!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190821
So after that I figured out that in order to get the proper ride height I needed a spacer under the leaves, so I used a piece of 1" by 1" bar stock as a small lift block for the leaf springs to get them sitting at the right angle.
It turned out quite well!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190825
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190826
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190827
They're just clamped down temporarily until I get a clamp down setup figured out, but she's holding 'er own weight!!
The next thing was making the grille fit right again:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190828
Just did a couple cut-outs near the bottom, worked quite well:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190829
Needs just a bit more trimming I think, but it clears pretty good and actually looks sorta neat, haha.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 20190830
She's coming along pretty good now!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeAugust 10th 2019, 5:01 pm
Hood looks mint! This may have been asked before, but what type rear tires are you using?
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 10 Icon_minitimeAugust 10th 2019, 7:28 pm
Great Progress! Lovin the setup.
Page 10 of 15Go to page : Previous  1 ... 6 ... 9, 10, 11 ... 15  Next
» [FINALIST] - Father Daughter project 2019 Build Off [2019 Build-Off Entry]
» [FINALIST] - Murraymountain's Mountain Murray [2019 Build-Off Entry]
» [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry]
» [FINALIST] - mrshaft696's The Real Horse [2019 Build-Off Entry]
» [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2019 Archive :: Finalist Archive-
